Here's a new scan done with the 12.12 VCDS still no error codes for the rear door and all the bytes are tick as they should be.......Still confused.
Sunday,25,May,2014,19:34:06:13746
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
Dealer/Shop Name: Daniel Miller
Workshop Code: 123 12345 012345
VIN: WAUZZZ.............. License Plate: 25/05/2014
Mileage: 73260km-45521mi Repair Order:
Chassis Type: 8P (1K0)
Scan: 01 02 03 08 09 10 15 16 17 19 22 25 37 42 44 46 52 55 56 62
65 72 77
VIN: WAUZZZ8P7AA093062 Mileage: 73260km/45521miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Cannot be reached 1100
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (CDL) Labels: 06F-907-115-CDL.clb
Part No SW: 8P0 907 115 AP HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0010
Revision: 5BH16--- Serial number: AUX7Z0INFNA10J
Coding: 0103000C1C0F0160
Shop #: WSC 00772 129 00000
VCID: 80096769D336311E1B7-80D5
1 Fault Found:
001089 - EVAP Emission Control Sys
P0441 - 002 - Incorrect Flow - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 72979 km
Time Indication: 0
Date: 2014.05.15
Time: 13:35:28
Freeze Frame:
RPM: 814 /min
Load: 26.7 %
Speed: 0.0 km/h
Temperature: 84.0°C
Temperature: 43.0°C
Absolute Pres.: 1020.0 mbar
Voltage: 13.716 V
Readiness: 0000 0000
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 013 N HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2601
Revision: 05351113 Serial number: 00001103120520
Coding: 0000020
Shop #: WSC 06314 000 00000
VCID: 1C31B319DF9E75FE67F-8049
No fault code found.
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AJ HW: 1K0 907 379 AJ
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 16428012092B00FD680B01EA901B00813D0000
Shop #: WSC 12345 123 12345
VCID: 7AFD9581F5EAEBCED53-802F
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 BL HW: 8P0 820 043 BL
Component: KlimavollautomatH09 0140
Revision: 000297 Serial number: 8P0820043BL
Shop #: WSC 00000 000 00000
VCID: 77FB8CB506F8F6A6AAD-8022
Address 09: Cent. Elect. (J519) Labels: 8P0-907-063.clb
Part No SW: 8P0 907 063 A HW: 8P0 907 063 A
Component: BCM PQ35 M 105 0575
Revision: 00105 AJ
Coding: 0E000A3FE827F0C0207241E00100895C457E2BAA307DD969E40040840040
VCID: 326D7DA16D1AD38E5D3-8067
Subsystem 1 - Part No SW: 8P2 955 119 F HW: 8P2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H11 0050
Coding: 00DD13
Subsystem 2 - Part No SW: 8K0 910 557 HW: 8K0 955 559 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSEN H04 0003
Coding: 024C2D
Subsystem 3 - Part No: 8P0 951 177
Component: Innenraumuebe H04 0020
Subsystem 4 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 5 - Part No: 1K0 907 719 C
Component: Neigungssenso 005 0003
Address 10: Park/Steer Assist (J446) Labels: 8P0-919-475-7X1.clb
Part No SW: 8P0 919 475 G HW: 8P0 919 475
Component: PARKHILFE 4K H06 0120
Revision: 11001001 Serial number: 93640931709286
Coding: 000103
VCID: 428D2D61DDBA630ECD3-8017
Address 15: Airbags (J234) Labels: 8P0-959-655-10.clb
Part No SW: 8P0 959 655 P HW: 8P0 959 655 P
Component: Airbag AU1042 H06 0160
Revision: -------- Serial number: 003FB00470HE
Coding: 30314238303830303037554A305238503053
ASAM Dataset: EV_Airba10AURB4 001001
ROD: EV_Airba10AURB4.rod
VCID: 4FAB145516E89E6652D-801A
Crash sensor for side airbag; driver side:
Serial number: 3572DRB40000D920EAA1
Crash sensor for side airbag; passenger side:
Serial number: 3582DRB40000D91CAB22
Crash sensor for side airbag; rear driver side:
Serial number: 35128RB4000051F70159
Crash sensor for side airbag; rear passenger side:
Serial number: 35228RB4000051F6035B
Crash sensor for front airbag; driver side:
Serial number: 35547RB400006213589E
Crash sensor for front airbag; passenger side:
Serial number: 35647RB4000062135F7K
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
Component: J0527 H37 0070
Coding: 0014142
VCID: 4685317131925F2EE1B-8013
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H06 0030
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 982 K HW: 8P0 920 982 K
Component: KOMBIINSTR. VDO H03 0990
Revision: D0H03004 Serial number: 224NI004000958
Coding: 0001418
VCID: 418F226D18BC7816D49-8014
Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H16 0231
Revision: H16 Serial number: 4320K09B09063D
Coding: EDA37F07400602003103
VCID: 69DFDACD404C50562C9-803C
1 Fault Found:
01325 - Control Module for Tire Pressure Monitoring (J502)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 4
Mileage: 72621 km
Time Indication: 0
Address 22: AWD Labels: Redir Fail!
Part No SW: 0BR 907 554 B HW: 0BR 907 554 B
Component: Haldex 4Motion 3017
Coding: 0000005
VCID: 44812B7907AE6D3EFFF-8011
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H03004 Serial number: AUX7Z0INFNA10J
Shop #: WSC 00137 211 56823
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8P0 035 193 G HW: 8P0 035 193 G
Component: RNS-E PU EU H06 0220
Revision: 0000012S Serial number: AUZBZ7LD201789
Coding: 0200757
VCID: 34617BB9570EDDBE4FF-8061
Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX3.lbl
Part No SW: 8P0 959 801 M HW: 8P0 959 801 M
Component: Tuer-SG H04 0100
Coding: 0004788
VCID: 4587367D0C945436E81-8010
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 234 3201
Revision: 00H20000
Shop #: WSC 02069 000 90108
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 8P0 959 802 M HW: 8P0 959 802 M
Coding: 0004788
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P3 907 357
Component: Dynamische LWR H01 0010
Revision: 00000001 Serial number:
Coding: 0000013
VCID: FAFD1581B5EA6BCE553-80AF
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0200757
Address 62: Door, Rear Left Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 F HW: 8P4 959 802 F
Component: Tuer-SG H04 0050
Coding: 0000144
Shop #: WSC 38100 001 1012557
VCID: 4383286502A06A06C65-8016
Address 72: Door, Rear Right Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 F HW: 8P4 959 801 F
Coding: 0000144
Shop #: WSC 06314 000 1012544
VCID: 428D2D611DBA630ECD3-8017
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 AA HW: 8P0 862 335 S
Component: FSE_256x BT H38 0600
Revision: 00000000 Serial number: 00000005143603
Coding: 0011422
VCID: 75E786BD1CF484B6B81-8020
Any more pointers.................................
Cheers Dan
