JMB RetrofitsEM Tuning
Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By 0120raptor
Thread: £250
    Nov 2013
    27
    £250
    I`m offering £250 cash to anyone who can tell me 100% why my car misfires.See Diesel Forum 19 Jan "A3 Boost Problem" Since then I`ve have replaced G31 G42 and turbo .Any takers? Bolton area.
    27,096
    Car data may help a diagnosis.
    warren_S5's Avatar
    Oct 2007
    7,163
    Wiring harness on top of engine?
    If I'm right give the £250 to charity!(unlikely but I'll keep guessing)
    Audi S5 3.0V6T Coupe Black Edition
    warren_S5's Avatar
    Oct 2007
    7,163
    Crankshaft position sensor
    Fuel filter
    Vacuum pipes...
    Nov 2013
    27
    Warren
    Surely the harness would show something odd during vcds logging which it doesn`t. C.P.S. changed also fuel filter, all vac pipes,tandem pump,injectors,turbo,N75,MAP,MAF,air temp sensor,fuel temp sensor.boost leak check,torsion 0*, etc.etc.No fault codes .The only thing I can think of is I`ve had EGR delete and DPF gutted and the exhaust sounds hissy even at idle.Could the rear silencer be blocked with all the soot that the DPF now can`t collect?
    That`s an extremely generous offer on the money but so far I still have the miss.
    Neil
    Nov 2013
    27
    ednesday,26,March,2014,19:10:30:44437
    VCDS -- Windows Based VAG/VAS Emulator
    VCDS Version: 12.12.2.0
    Data version: 20140212
    Dealer/Shop Name: Bold Engineering
    VIN: WAUZZZ8P17A136397 License Plate: N8OLD
    Mileage: 142250km-88390mi Repair Order:
    Chassis Type: 8P (1K0)
    Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 52 56 62 72
    VIN: WAUZZZ8P17A136397 Mileage: 142250km/88390miles
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    22-AWD -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    Address 01: Engine Labels: 03G-906-018-BMN.clb
    Part No SW: 03G 906 018 DN HW: 03G 906 018 DN
    Component: R4 2.0l PPD1.2 4350
    Revision: --H42--- Serial number: AUX7Z0FDFNC11D
    Coding: 0000072
    Shop #: WSC 66565 257 00032
    VCID: 74E7D3921716BABE8FF-8021
    No fault code found.
    Readiness: N/A
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-A.lbl
    Part No SW: 1K0 907 379 AB HW: 1K0 907 379 AB
    Component: ESP 4MOTION MK60 0102
    Revision: 00H13001
    Coding: 0023170
    Shop #: WSC 06314 000 00000
    VCID: 72EBD58A6D02B48E9D3-8027
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 AC HW: 8P0 820 043 AC
    Component: KlimavollautomatH19 0360
    Revision: 082189 Serial number: 8P0820043AC
    VCID: 6DD1C6F6743C6B76401-8038
    Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
    Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
    Component: Bordnetz-SG H43 1201
    Revision: 00H43000 Serial number: 00000006497371
    Coding: 01884F01B014100000160000160000000008FE175C0100
    Shop #: WSC 06314 000 08192
    VCID: 408F4F42132E561EDB7-8015
    Subsystem 1 - Part No: 8P2 955 119 E Labels: 1KX-955-119.CLB
    Component: Wischer AU350 H01 0130
    Coding: 00062736
    Shop #: WSC 06314
    Address 15: Airbags Labels: 8P0-959-655-94.lbl
    Part No SW: 8P0 959 655 C HW: 8P0 959 655 C
    Component: Airbag 9.41 H13 4260
    Revision: 91H13426 Serial number: 003620G37HZ3
    Coding: 0071612
    VCID: 428B454A1D22440ECD3-8017
    Subsystem 1 - Serial number: 6332DRB404559013A
    Subsystem 2 - Serial number: 6342DRB404559113C
    Subsystem 3 - Serial number: 63528RB401F2E627R
    Subsystem 4 - Serial number: 63628RB401F2E499Z
    Subsystem 5 - Serial number: 63729RB401E5BC65.
    Subsystem 6 - Serial number: 63829RB401E5BC08Z
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 AH HW: 1K0 953 549 AH
    Component: J0527 036 0070
    Coding: 0000012
    VCID: 78FFE7A20B7EDEDEA37-802D
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
    Part No SW: 8P0 920 981 F HW: 8P0 920 981 F
    Component: KOMBIINSTR. VDO H20 0570
    Revision: D0H20004 Serial number: 224DF004008288
    Coding: 0005418
    Shop #: WSC 00694 210 83007
    VCID: 3B7538AE7AC835C68E5-806E
    Address 19: CAN Gateway Labels: 1K0-907-530-V2.clb
    Part No SW: 1K0 907 530 K HW: 1K0 907 951
    Component: J533__Gateway H12 0170
    Revision: H12 Serial number: 3300106B2204E4
    Coding: BD3F034007002103
    VCID: 2F6D1CFEBEB0D96632D-807A
    Address 22: AWD Labels: 1K0-907-554.lbl
    Part No: 1K0 907 554 L
    Component: Haldex 4Motion 0116
    Coding: 0000001
    Shop #: WSC 00000 000 00000
    VCID: 3663299A41EAE8AE71B-8063
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Revision: D0H20004 Serial number: AUX7Z0FDFNC11D
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN2.lbl
    Part No: 8P0 959 801 H
    Component: Tuer-SG 020 0090
    Coding: 0000688
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K2 909 144 L
    Component: EPS_ZFLS Kl.079 H07 1806
    VCID: 35612E965CECE3B6781-8060
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433 F
    Component: KSG H05 0070
    Coding: 9980202002186D098505489FC637
    VCID: 3F8D4CBE6ED029E6A2D-806A
    Subsystem 1 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Subsystem 2 - Part No: 1K0 907 719 C
    Component: Neigungssensor 005 0003
    Subsystem 3 - Part No: 8P0 951 177
    Component: Innenraumueberw.H04 0020
    Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN2.lbl
    Part No: 8P0 959 802 H
    Coding: 0000688
    VCID: 41894A4618245F16D49-8014
    Address 56: Radio Labels: 8J0-035-1xx-56.clb
    Part No SW: 8P0 035 195 G HW: 8P0 035 195 G
    Component: R Symphony2+ H14 0220
    Revision: 00H14000 Serial number: AUZ1Z4F9005576
    Coding: 0010301
    1 Fault Found:
    01044 - Control Module Incorrectly Coded
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 255
    Time Indication: 15
    Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
    Part No: 8P4 959 801 D
    Component: Tuer-SG 020 0070
    Coding: 0000144
    Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
    Part No: 8P4 959 802 D
    Coding: 0000144
    warren_S5's Avatar
    Oct 2007
    7,163
    If your certain it's not crankshaft position sensor then maybe look at getting the exhaust dropped off and checked as there shouldn't be a hiss when you're running. It's not a hugely expensive job or massive effort to do. Who did the EGR delete / DPF gut, and are you confident the work was 100%. I can't see any issues such as misfires coming from anywhere behind the centre section of the exhaust. Has the car been mapped for the exhaust modifications, and if so by who?
    warren_S5's Avatar
    Oct 2007
    7,163
    Some more guesses:
    1) Anti shudder valve (throttle valve - supposedly can strip plastic teeth and fail)
    2) Injector flow rate (were new injectors fitted with new seals - e.g. could these be hissing?)
    3) Compression test cylinders to make sure they are all in tolerance (Check cylinder no.3 in particular)
    4) Long shot - DMF (can mimic what seems like a misfire)
    When they do the EGR delete do they remove all of it (electronic & vacuum part)?
    Nov 2013
    27
    Warren
    CRD Performance in Bolton did the EGR,DPF and remap.They gutted the DPF properly ,opening it up so it`s empty. I saw it being done.
    The car ran superbly for months then started to miss at 2000-2400 only under hard acceleration.Under gentle acceleration no problem.
    I thought it may be a boost spike but vcds only goes to 2601 mbars.and requested and actual are 2601.
    Anti shudder valve`s ok by visually watching gears move and by vcds.
    Injector seals and both tandem pumps must be ok as oil level doesn`t go up and there`s no oil in filter housing.
    Haven`t checked injector flow rate or compressions but the way the engine starts instantly hot or cold suggest comps are ok.
    Had a new DMF with complete clutch a few months back.
    EGR was deleted electronically and I also blanked it off mechanically.
    Maybe I should up it to £500.
    Neil
    warren_S5 likes this.
    Jul 2007
    London
    3,238
    Quote Originally Posted by 0120raptor View Post
    Warren
    Neil
    Bring it to London and leave it with me for a week-end or so, i should be able to find out the issue...
    FOR SALE:
  1. 250 - dilemma
    By Geordie Mike in forum General Chat
    Last Post: 10th October 2007, 08:07
  2. 15MPG - WTF - 60litres for 250 miles:
    By imported_ZeroK66 in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th September 2005, 17:30
  3. Win a 250 bhp Audi A3 V6
    By bravepilot in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd December 2004, 08:54
  4. S3 225hp or new A3 3.2 V6 250 hp????
    By celso in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd January 2004, 09:38
  5. Just bought some Alu mirrors for 250!!
    By dans3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th February 2003, 21:51
