GNJRevo Technik
Thread: Any ideas?
    imported_Tariq's Avatar
    Jul 2004
    152
    Post Thanks / Like
    Any ideas?
    Hi i plugged my car into Vagcom and its come up with:
    17698 - Coolant Temp Sensor at Radiator Outlet (G83): Signal too Small
    P1290 - 35-00 - -
    17524 - Oxygen (Lambda) Sensor Heating: B1 S1: Open Circuit
    P1116 - 35-00 - -
    Any ideas?
    T
    Grant's Avatar
    Dec 2003
    Kintore, Aberdeenshire, United Kingdom
    1,037
    Post Thanks / Like
    Re: Any ideas?
    Do you have a black or green top temperature sensor?
    Located to the right of the engine.
    If you have the black top, replace it for the green top version.
    A faulty or black top version can cause a loss in power/boost.
    peteA3tdi's Avatar
    Mar 2004
    the rose and crown
    406
    Post Thanks / Like
    Re: Any ideas?
    what car and engine size is it?
    clear the codes test drive and see if they come back
    Jul 2004
    152
    Post Thanks / Like
    Re: Any ideas?
    Hi i finally got round to replacing the sensor however still no joy eve though i replaced it with the green one. My lamba sensor is also not giving any readings....
