Chris NottVolks Autos
    markm,'s Avatar
    Feb 2014
    Portsmouth
    49
    Virgin VCDS user needs help coding Fiscon Bluetooth
    Hi All
    I've just been following the helpful guide on coding the Bluetooth for a Concert III head unit , I've following the instructions doing a dry run ready for the weekends install.
    I've found where to add 4 to the 2nd digit here
    And 4 here, although I'm not sure IF I can use the voice option with the Fiscon , so may need to add 3 here ?
    But I cant access 77 , is this because the Fiscon unit isnt installed ?
    Help :-)
    Jan 2012
    1,837
    Fiscon can't be coded, you'll see that error even if the Fiscon is connected.
    27,121
    Rule of thumb, no module connected (except for virtual modules like eg. 4C tpms on some chassis) no access, even worse with fiscon.
  1. Newby VCDS user, help needed please
    By dt-tdi in forum VCDS (formerly VAG-COM) forum
    Last Post: 11th March 2014, 21:49
  2. VCDS user help needed in west midlands or Gloucester
    By SuperV8 in forum VCDS (formerly VAG-COM) forum
    Last Post: 18th October 2013, 21:44
  3. Need help cannot code bluetooth for RNS-E
    By strykerz in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd January 2013, 21:26
  4. Need help coding retrofit front foglights please !!
    By figgy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th November 2009, 19:27
  5. Engine swap - need help with codes
    By Pincher in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th August 2004, 22:33
