AH FabricationsVolks Autos
Results 1 to 10 of 10
    Feb 2014
    104
    VCDS Losing connection
    Hi all
    I'm having an issue getting my VCDS to do a full scan, half way through my laptop pings up with the following screen shot warning.
    I've tried re starting the laptop, disconnecting the lead from the car and it still happens, any ideas?
    David
    Jan 2012
    1,837
    We can't see it, it's too small.
    ruairi83's Avatar
    Dec 2007
    739
    same thing happened me and it was always at module 46. Contact ross tech and Jef will give you instructions on how to send debug file to find the problem. My one just disappeared after an update from ross tech.
    Feb 2014
    104
    Quote Originally Posted by ruairi83 View Post
    Emailed Ross Tech today and got a helpful reply from Uwe, just awaiting a further reply from the info I have sent him.
    Attached is a larger image of my problem which should now be visible.
    27,099
    Change this setting, see if it helps.
    Feb 2014
    104
    Hi Nigel
    I've changed the settings as you have advised and it seems to have done the trick.
    Did a full scan with the following results.
    I am getting access to all of the modules that my cable is allowed to?
    Sunday,09,March,2014,09:33:32:43365
    VCDS -- Windows Based VAG/VAS Emulator
    VCDS Version: 12.12.2.0 (x64)
    Data version: 20140212
    VIN: WAUZZZ8EX7A144772 License Plate: DT7734
    Mileage: 65820km-40898mi Repair Order:
    Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
    67 69 75 76 77
    VIN: WAUZZZ8EX7A144772 Mileage: 65820km/40898miles
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 8E0 910 401 N HW: 8E0 907 401 AL
    Component: 3.0L V6TDI G000AG 0050
    Revision: --H03--- Serial number: XXXXXXXXXXXXXX
    Coding: 0011171
    Shop #: WSC 66565 257 00032
    VCID: 2A5D6E2985564C4EE53-807F
    1 Fault Found:
    005661 - Glowplug for Cylinder 4 (Q13)
    P161D - 001 - Open Circuit
    Freeze Frame:
    Fault Status: 01100001
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 65747 km
    Time Indication: 0
    Date: 2064.00.00
    Time: 00:00:00
    Freeze Frame:
    RPM: 0 /min
    Torque: 0.0 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 11.17 V
    Duty Cycle: 15.0 %
    Temperature: 24.3°C
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans Labels: 09L-927-760.lbl
    Part No SW: 8E1 910 156 H HW: 09L 927 156 B
    Component: AG6 09L 3,0 TDI 171 0070
    Revision: --H01--- Serial number: 4256683
    Coding: 0000002
    Shop #: WSC 06325 000 00000
    VCID: 2C5168318FA2527E17F-8079
    No fault code found.
    Address 03: ABS Brakes Labels: 8E0-910-517.clb
    Part No SW: 8E0 910 517 J HW: 8E0 614 517 BH
    Component: ESP8 quattro H06 0140
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0004426
    VCID: 2E556239B9BE206E39B-807B
    Address 08: Auto HVAC Labels: 8E0-820-043.lbl
    Part No: 8E0 820 043 BM
    Component: A4 Klimaautomat 3233
    Coding: 00000
    Shop #: WSC 00000
    VCID: 6DD7A53527389B76401-5196
    Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
    Part No: 8E0 907 279 N
    Component: int. Lastmodul ECE 0907
    Coding: 00001
    Shop #: WSC 06325
    VCID: 3D77557537D8CBF6B01-4B32
    Address 15: Airbags Labels: 8E0-959-655-94.lbl
    Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
    Component: Airbag 9.41 H12 3730
    Revision: 91H12373 Serial number: 0036M0G4MUU4
    Coding: 0031612
    VCID: 3B735B6D7ACCC5C68E5-806E
    Subsystem 1 - Serial number: 6332DRB404360C9EV
    Subsystem 2 - Serial number: 6342DRB4042AD42BU
    Subsystem 3 - Serial number: 6352ARB401D63E67W
    Subsystem 4 - Serial number: 6362ARB401D6387AV
    Subsystem 5 - Serial number: 63729RB401D9773CZ
    Subsystem 6 - Serial number: 63829RB401D9770AV
    Address 16: Steering wheel Labels: 8E0-953-549.lbl
    Part No: 8E0 953 549 Q
    Component: Lenksáulenmodul 0701
    Coding: 02041
    Shop #: WSC 06325
    VCID: 418F29854B20AF16D49-4B18
    Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
    Part No SW: 8E0 920 983 A HW: 8E0 920 983 A
    Component: KOMBI+WFS 4 H14 0200
    Revision: 0200 Serial number: 00000000000000
    Coding: 0007418
    Shop #: WSC 01189 210 175629
    VCID: 2D576535B7B85B76001-515A
    1 Fault Found:
    01304 - Radio
    004 - No Signal/Communication - Intermittent
    Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
    Coding: 0007418
    VCID: 2D576535B7B85B76001-5178
    1 Fault Found:
    01304 - Radio
    Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
    Part No: 8E0 951 177
    Component: Innenraumueberw. 0804
    Coding: 00001
    Shop #: WSC 00000
    VCID: EBD32B2D992C1546DE5-515A
    Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
    Part No: 8E0 959 433 CH
    Component: Komfortgerát T3B 4135
    Coding: 06895
    Shop #: WSC 06325
    VCID: 79FF8165637037D6DC9-4B18
    Subsystem 1 - Part No: 8E2959802F
    Component: Tõrsteuer.FS BRM 0606
    Subsystem 2 - Part No: 8E2959801F
    Component: Tõrsteuer.BF BRM 0606
    Subsystem 3 - Part No: 8E0959801E
    Component: Tõrsteuer.HL BRM 0606
    Subsystem 4 - Part No: 8E0959802E
    Component: Tõrsteuer.HR BRM 0606
    1 Fault Found:
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    Address 76: Park Assist Labels: 8E0-919-283-8EC.lbl
    Part No SW: 8E0 919 283 E HW: 8E0 919 283 E
    Component: Parkhilfe 8-Kan H06 0010
    Revision: 00H06000 Serial number: 00067802130629
    Coding: 0001104
    VCID: 326D7649AE86048E5D3-515A
    End
    27,099
    Seems to read ok, except for radio of which I've advised via PM how to address possibly, keep all replies on here from now on please.
    Feb 2014
    104
    Tried to do another auto scan today and I'm stilling having the same problem as above with losing connection at module 46.
    Have also tried accessing module 46 directly and the message 'No response from controller' flags up?
    I tried my partners laptop just to be sure it wasn't an issue with my laptop and the result was the same.
    Beginning to think there may be a fault with the module on my car?
    Anyone got any ideas?
    27,099
    It may have got water damaged, check under bonnet for blockage of drain areas.
    major water leak problem A4 Drivers side rear footwell soaking wet
    Feb 2014
    104
    I do have a factory fitted sunroof so the drain holes may be blocked?
    Where a bouts is module 46 located in the car so I can check it and the wiring?
  1. please help cant connect to vcds
    By BeeKay in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd August 2013, 23:02
  2. Losing power on 2nd???? any ideas
    By HSM in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th November 2003, 11:58
  3. Arial connection
    By gburgess in forum In-Car Entertainment
    Last Post: 1st November 2003, 18:32
  4. S4 losing boost
    By fatarnie in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd August 2003, 22:27
  5. does my intake make me lose power?
    By Baudiquattro in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th July 2003, 09:53
