- Joined
- May 25, 2012
- Messages
- 1,813
- Reaction score
- 200
- Points
- 63
- Location
- Hull, UK
- Website
- www.immotec.co.uk
It appears this car is stuck in an initialization mode? No known work carried out leading to the fault as far as im aware, in the measuring blocks in 44 it would appear angle is not reading/changing from zero.
Steering stop limit adaption failed using the full lock left and right and centre method.
Basic settings not available, just error out.
Am i missing something here or is the G85 goosed?
Also is the AUX heater on this A3 the 1 cylinder desel kind you find in the pheaton/A6 etc? Or something else as output tests suggested the unit was firing up, but no control as an aftermarket head unit was installed..
Any info would be useful as im having a blonde moment!
Tuesday,04,March,2014,22:11:44:05185
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: WAUZZZ8P96A066517 License Plate:
Mileage: 215770km-134073mi Repair Order:
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72 7D
VIN: WAUZZZ8P96A066517 Mileage: 215770km/134073miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Cannot be reached 1100
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
7D-Aux. Heat -- Status: Malfunction 0010
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 J
Component: EPS_ZFLS Kl.5 D04 1606
Shop #: WSC 00000 000 00000
VCID: 3365A10752212986591-8066
2 Faults Found:
02546 - Steering Limit Stop
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Mileage: 5760 km
Temperature: 9.0°C
Voltage: 11.80 V
Voltage: 11.60 V
00778 - Steering Angle Sensor (G85)
000 - -
Freeze Frame:
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D51B77FB4057F760F5-8078
1 Fault Found:
00361 - Heater Element for Auxiliary Heater (Z35)
014 - Defective
2 Faults Found:
Freeze Frame:
Mileage: 5760 km
Temperature: 9.0°C
Voltage: 11.80 V
Voltage: 11.60 V
000 - -
Freeze Frame:
1 Fault Found:
014 - Defective
