JMB RetrofitsChris Nott
    Jan 2014
    Airbag module Voltage too High / Airbag module Internal electronic failure
    Hi Guys
    Please help!!!!!!! our A4 B8 2008 2TDI has the airbag light on i have scaned it and it comes back with :-
    2 Faults Found:
    13636096 - Supply voltage
    U1012 00 [137] - Voltage too High
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 53
    Mileage: 167356 km
    Date: 2007.10.26
    Time: 00:24:06
    10485833 - Internal Control Module Memory Check Sum Error
    B2000 49 [137] - Internal electronic failure
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Mileage: 167356 km
    Date: 2007.10.26
    Time: 00:01:06
    Has anyone come across this befor is it easy to reprogam a replasment module.
    Thankyou
    Paul
    Feb 2014
    26
    Visit L33AEX's Instagram Channel
    Ive found with the airbag faults if there isn't a genuine problem or the air bag has been disconnected then reconnected the fault tends to clear after clearing.
    I think its more than likely an air bag module.
    I think you'd be better off replacing it personally.
  1. will this sit too high?
    By skanky in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th August 2006, 13:22
  2. S3 Driving Position - Too High?
    By StephenBogan in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th September 2004, 14:59
  3. X-post for a friend: A3 Oil consumption too high
    By ImolaS4 in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th July 2004, 13:13
  4. New A3 Wiper Motor Replaced, Is the wiper too high
    By Rolex1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th February 2004, 20:37
  5. Too high Service Costs?
    By Naresh in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd April 2003, 19:17
Tags for this Thread
