Forge MotorsportSky Insurance
    LPG Abuser & have VAGCOM
    Aug 2005
    Essex
    130
    Post Thanks / Like
    Running Rich or Lean???
    Im running a new type of LPG system on my 2000 A4 and doing some development work, Im getting the following error code up after a long drive:
    00561 - Mixture Adaptation
    14-00 - Adaptation Limit (Add) Exceeded
    Is this meaning that it is running too weak and it has reached the limit of adding?? or otherwise?????
    Many Thanks
    Michael
    Jul 2005
    2,487
    Post Thanks / Like
    Re: Running Rich or Lean???
    there was a good post here not so long ago detailing the differences between Mixture adaptations and trim. Have a quick search.. one is to do with idle mixture, the other is to do with accelerating mixture.
    Byzan Pics's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    10,709
    Post Thanks / Like
    Slightly weak, mine was fixed after changing some vacuum hoses and a new MAF, not sure which one did it, but it's gone now,lol
    Aug 2005
    Essex
    130
    Post Thanks / Like
    Ok, so to start off with I will try and run either bigger injector jets or increase the pressure on the rail.
    Michael
