Q7 Scan results
Gavin0478
Active Member
cleveland
Hi just ran my first scan on my recent Q7 to get these faults.
Just after some advice before it gets sent back under warranty.
Cheers.
Mileage: 28210km/17528miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
11-Engine II -- Status: OK 0000
31-Engine other -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
18-Aux. Heat -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
20-High Beam Assist. -- Status: OK 0000
28-HVAC, Rear -- Status: OK 0000
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
3C-Lane Change -- Status: Malfunction 0010
3D-Special Function -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: Malfunction 0010
4C-Tire Pressure II -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
57-TV Tuner -- Status: OK 0000
5C-Lane Maintain. -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: Malfunction 0010
69-Trailer -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
6F-Centr. Conv. II -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 0010
76-Park Assist -- Status: OK 0000
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 B HW: 4F0 905 852 F
Component: FBSAUDIC6 ELV H05 0130
Revision: 00H05000 Serial number: 10602901641732
Coding: 0000215
Shop #: WSC 31414 790 00001
VCID: 254797A9ECD74136C75-8070
Subsystem 1 - Part No: 4F0 910 132 G
Component: FBSAUDIC6 EZS H03 0020
Subsystem 2 - Part No: 4F0 910 335 B
Component: FBSAUDIC6 KSG H03 0020
Subsystem 3 - Part No: 4F0 910 220 K
Component: FBSAUDIC6 IDG H01 0053
5 Faults Found:
00190 - Driver's Door Handle Touch Sensor (G415)
007 - Short to Ground
Freeze Frame:
Fault Status: 01110111
Fault Priority: 3
Fault Frequency: 1
Reset counter: 2
Time Indication: 0
00193 - Rear Right Door Handle Touch Sensor (G418)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 2
Time Indication: 0
00192 - Rear Left Door Handle Touch Sensor (G417)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 104
Mileage: 27926 km
Time Indication: 0
Date: 2014.01.14
Time: 06:01:43
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00111000
Fault Priority: 3
Fault Frequency: 3
Reset counter: 56
Mileage: 24619 km
Time Indication: 0
Date: 2013.05.09
Time: 14:16:00
Freeze Frame:
Fault Status: 00111011
Fault Priority: 3
Fault Frequency: 4
Reset counter: 143
Mileage: 24490 km
Time Indication: 0
Date: 2013.04.20
Time: 10:43:55
Address 17: Instruments (J285) Labels: 4L0-920-xxx-17.clb
Part No SW: 4L0 920 983 L HW: 4L0 920 983 L
Component: KOMBIINSTR. H10 0209
Revision: 00000000 Serial number: FLD40V38A
Coding: 2F5663040D012600010400
VCID: 3B7351D1BA53E7C6811-806E
1 Fault Found:
00003 - Control Module
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 1
Mileage: 24382 km
Time Indication: 0
Date: 2010.04.16
Time: 16:34:15
Address 18: Aux. Heat Labels: None
Part No SW: 4L0 910 105 HW: 4L0 815 071 G
Component: Heizgeraet H09 0140
Revision: 0000000C Serial number: 00000009021078
Coding: 0000001
VCID: E0C946BD3375641E743-80B5
2 Faults Found:
01444 - Under-Voltage Shut-Off (Automatic)
000 - - - Intermittent
00664 - Fuel gauge
002 - Lower Limit Exceeded
Address 19: CAN Gateway (J533) Labels: 4F0-907-468.clb
Part No SW: 4F0 907 468 Q HW: 4F0 907 468 G
Component: GW-BEM 5CAN-M H06 0047
Revision: MB300033 Serial number: 3300M10718817C
Coding: 00C303
VCID: 3D775FC9A447E9F6BF5-8068
Subsystem 1 - Part No SW: 8K0 915 181 D HW: 8K0 915 181 D
Component: J367-BDM H07 0125
1 Fault Found:
03041 - Energy Management Active
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 53
Reset counter: 152
Mileage: 24596 km
Time Indication: 0
Date: 2013.05.07
Time: 08:35:41
Freeze Frame:
Bin. Bits: 00000
Voltage: 11.50 V
Count: 11
Address 34: Level Control Labels: None
Part No SW: 4L0 910 553 H HW: 4L0 907 553
Component: LUFTFDR.-CDC H03 7870
Revision: --H03001 Serial number: 15.1528-0123.2
Coding: 0015520
Shop #: WSC 10886 000 1048576
VCID: 2F6B7581BE2B0B663D9-807A
3 Faults Found:
03004 - Load Level Button (E539)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 4
Fault Frequency: 1
Reset counter: 168
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Error Code: 156
01577 - Turn-Off due to Over-Temp
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 6
Fault Frequency: 11
Reset counter: 168
Mileage: 25019 km
Time Indication: 0
Date: 2013.05.12
Time: 16:22:14
Freeze Frame:
Error Code: 68
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 4
Fault Frequency: 8
Reset counter: 168
Mileage: 26926 km
Time Indication: 0
Date: 2013.09.10
Time: 09:34:41
Freeze Frame:
Error Code: 13
Address 3C: Lane Change Labels: None
Part No SW: 4L0 910 566 C HW: 4L0 907 566 B
Component: J0769_SWA_MasterH01 0050
Revision: 00H01000 Serial number: 6PZ 009 014-10
Coding: 0011101
VCID: 2E556885B921026E36F-807B
Subsystem 1 - Part No: 4L0 910 568 C
Component: J0770_SWA_Slave_H01 0050
Subsystem 2 - Serial number: 6PZ 009 014-30
Subsystem 3 - Serial number: 5F15.08.1000H010003C910101ÿ
Subsystem 4 - Serial number: 910101ÿ
1 Fault Found:
01316 - ABS Control Module
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 4
Fault Frequency: 1
Reset counter: 146
Mileage: 28080 km
Time Indication: 0
Date: 2014.01.19
Time: 13:18:07
Address 3D: Special Function Labels: 8K0-907-440.clb
Part No SW: 8K0 907 440 HW: 8K0 907 440
Component: STS H04 0040
Revision: S0H04000 Serial number: 00000000022874
Coding: 01010101000000000000000202
VCID: EBD32191CAB33746D11-80BE
1 Fault Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 117
Mileage: 27118 km
Time Indication: 0
Date: 2013.11.11
Time: 11:18:26
Address 42: Door Elect, Driver (J386) Labels: 4F0-959-793.clb
Part No SW: 4F0 959 793 T HW: 8K0 959 793 M
Component: TSG FA H12 0361
Revision: Serial number: 0004000152712
Coding: 011F56205E61440204
VCID: 48993E1DFB85BC5E1C3-801D
1 Fault Found:
02126 - Central Locking Button; Exterior Door Handle
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 7
Reset counter: 149
Mileage: 27811 km
Time Indication: 0
Date: 2014.01.06
Time: 16:07:53
Address 47: Sound System (J525) Labels: None
Part No SW: 4L0 035 223 G HW: 4L0 035 223 G
Component: BOSE G3 Q7 H03 0040
Revision: CH003000 Serial number: 00000000004221
VCID: 264590A551D14A2ECEF-8073
1 Fault Found:
03278 - Functionality Limited due to Missing Messages
Freeze Frame:
Fault Priority: 6
Fault Frequency: 32
Reset counter: 152
Mileage: 24533 km
Time Indication: 0
Date: 2013.04.25
Time: 08:40:02
Freeze Frame:
Bin. Bits: 00000001
Address 52: Door Elect, Pass. (J387) Labels: 4F0-959-792.clb
Part No SW: 4F0 959 792 T HW: 8K0 959 792 M
Component: TSG BF H12 0361
Revision: Serial number: 0004000153278
VCID: 479B3D21F69BB326159-8012
1 Fault Found:
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 7
Reset counter: 84
Mileage: 27118 km
Time Indication: 0
Date: 2013.10.29
Time: 01:39:18
Address 62: Door, Rear Left (J388) Labels: 4F0-959-795.clb
Part No SW: 4F0 959 795 P HW: 4F0 959 795 P
Component: TSG HL H11 0361
Revision: Serial number: 0004000148669
Coding: 010E56204061230204
VCID: 46853025F191AA2EEEF-8013
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 27
Reset counter: 99
Mileage: 27118 km
Time Indication: 0
Date: 2013.11.22
Time: 10:42:11
Address 69: Trailer (J345) Labels: 4E0-907-383.clb
Part No SW: 4E0 907 383 J HW: 4E0 907 383 J
Component: Anhaenger H08 0070
Revision: 2A001001 Serial number: 00000133435626
Coding: 0100000100000000
VCID: 316F73F9681F1D962BD-8064
2 Faults Found:
02562 - Trailer; Brake Lamps
010 - Open or Short to Plus - MIL ON
Freeze Frame:
Fault Status: 11101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 70
Mileage: 26994 km
Time Indication: 0
Date: 2013.09.20
Time: 12:14:12
02563 - Trailer; Right Tail Lamps (M61)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 70
Mileage: 26994 km
Time Indication: 0
Date: 2013.09.20
Time: 12:14:13
Address 72: Door, Rear Right (J389) Labels: 4F0-959-795.clb
Component: TSG HR H11 0361
Revision: Serial number: 0004000148624
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 70
Reset counter: 112
Mileage: 27118 km
Time Indication: 0
Date: 2013.11.01
Time: 05:22:18
The battery was replaced under warranty before my ownership.
Will re scan after a good run tomorrow but enabled battery meter and its showing 50%!!!
they are codes from a battery been dead so more than likely didnt clear faults. usuall practice if it was replaced by Audi.
its the small things they miss out on.
