Logging Coding & Adaptations
coxy8329
Hampshire
Hopefully somebody will be able to answer this.
Is it possible to log the coding and adaptation settings for the modules using VCDS?
Or is it a case of writing it all down by hand?
Save an autoscan before you make changes. Save an autoscan after you make changes.
Also, changes you make are recorded in the log file as you make them. Check the Log folder in your VCDS installation.
Reactions: NHN
As above, but you can do a controller map for adaption channels per module, some may require security access, I cant recall totally as been a while since I did.
Thanks Nigel, I think that's what I need to do to record the Adaption settings for each module. Will see what I can find on the RossTech website.
Thanks Bruce, I'd not noticed the 'Module Coding' had been recorded in the AutoScan Logs.
20
106K
2K
822
2K
