EM TuningChris Nott
Like Tree1Likes
  • 1 Post By christof71
Thread: Fault Found: 01539 - Headlights Not Adjusted [urgent]
    s3_trev's Avatar
    Nov 2013
    373
    Hi folks, have a bit of a problem here. I drive a 2009 audi s3 8p, and tonight I decided to adjust the level of the cars bi-xenon lights. The car is lowered 30mm on H&R springs and I thought that the lights have not been as good since the lowering, hence wanting to get them checked.
    So I followed this guide:
    Ross-Tech: VAG-COM: Xenon Headlamp Adjustment
    Looks simple enough. So I booked the car into a local mechanic, so that he could manually set the lights on the beam setter, when I had set the lights up to "adjustment position" via VCDS.
    I drove the car in, and before we done anything, he checked the lights on the beam setter. He told me that they were not too bad, but that he would like to see them about 2mm higher.
    So I started the procedure (turning the lights off as per the guide), but unfortunately when I got to the stage to click on "go" a few seconds later, my car brought up an error screen and message on the DIS saying "headlight range control defective". And I didn't really get any further after that! The little arrows that would allow me to scroll up to group 2, as the vcds wiki suggested, were grayed out, so all I could really do is just close the controller.
    Now, the mechanic told me that when I clicked go, and we were waiting the 20 seconds recommended for the lights to move, that the lights actually moved up by a couple of mm, and aligned themselves perfectly on the beam setter. Not too sure what to think about this?
    Anyway, this has now left me quite annoyed, as there is now a light taking up half my dash. I had no issues with my lights before starting this procedure, other than slightly poorer vision. When I clear the fault, it just appears again.
    From reading about this, it seems the only way to clear this fault, is to complete the learning procedure, but how can I do that if the car wont let me? I have read something about vehicle height sensors and control arms, could this be my issue? Are these arms/sensors underneath the car?
    I would really appreciate any help anyone can give!! Failing an answer here I will contact Ross-Tech as I do have a genuine cable and I registered with them a few weeks ago.
    Code:
    Wednesday,15,January,2014,17:34:44:12561
    VCDS -- Windows Based VAG/VAS Emulator
    VCDS Version: Release 12.12.0 (x64)
    Data version: 20130910
                    Address 55: Xenon Range       Labels: 8P0-907-357.LBL
    Control Module Part Number: 8P3 907 357
      Component and/or Version: Dynamische LWR  H01 0010
               Software Coding: 0000013
                Work Shop Code:
                          VCID:
    1 Fault Found:
                005 - No or Incorrect Basic Setting / Adaptation - MIL ON
                 Freeze Frame:
                        Fault Status: 11100101
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 20
                        Mileage: 55512 km
                        Time Indication: 0
                        Date: 2014.01.15
                        Time: 17:14:12
    Audi S3 8P3 / REVO Stage 1 / REVO Ceramic Intake / Revo PCV Revamp / NGK Iridium Spark Plugs / Philips Diamond Vision 5000k Fog Light Bulbs /
    KW V3 Coilovers / Team HEKO Wind Deflectors / Bridgestone Potenza S001 92Y Tyres / Complete LED Bulb Conversion (int' + ext') / Ashtray Delete /
    TTS Engine Cover / Alpine 928r Multimedia Station (8in screen) with integrated Bluetooth, Sat Nav etc / Ross-Tech VCDS Owner.
    s3_trev's Avatar
    Nov 2013
    373
    Another thing I forgot to mention was that before I done this, the car always done the lights down and lights back up again procedure every time I started it, so there was no issues with this.
    Also here is a screen shot of the "measuring blocks". Not sure if this is any help whatsoever but I saw it mentioned on the ross-tech wiki.
    May 2013
    60
    [Select]
    [55 - Xenon Range] (For some newer vehicles, use [29 - Left Light] instead )
    [Basic Settings - 04]
    Group 001
    [Go!]
    after manual adjusting DO NOT CHANGE FOR CHANEL 2 select - SAVE wait and must be message learned
    s3_trev likes this.
    s3_trev's Avatar
    Nov 2013
    373
    Thanks mate but already got this fixed in the sister thread to this one
    See post 28.
    And those instructions you posted actually didnt work but the below ones did
    [Select]
    [55 - Xenon Range]
    Group 001
    [Go!]
    Activate the Basic Setting.
    [ON/OFF/Next]
    The meas. block field now shows "Wait" and should switch to "Adjust Headlights" then (this may take up to 10 seconds).
    Adjust the headlights using their manual adjusting screws as referenced against a suitable aiming target.
    [ON/OFF/Next]
    The adjustment should now be learned.
    [Done, Go Back]
    Don't forget to check/clear fault codes afterwards.
    [Close Controller, Go Back - 06]
  1. Help please. 01539-Headlights Not Adjusted 005-No or Incorrect Basic Setting
    By Scimitar in forum VCDS (formerly VAG-COM) forum
    Last Post: 4th October 2012, 14:06
  2. A/C not working - Faults found:
    By Von Maximo in forum VCDS (formerly VAG-COM) forum
    Last Post: 29th April 2008, 08:32
  3. Headlight not working
    By DIPS_A4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th September 2006, 19:35
  4. Fault found
    By Mart in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th January 2006, 19:48
  5. Headlight height adjustment
    By Gaunty in forum Volkswagen and other VAG
    Last Post: 22nd December 2003, 16:53
