Badger5Chris Nott
    Jan 2014
    9
    Post vcds - manchester/ashton under lyne area?
    Just wondering if there is anyone local to me who could possibly do a vcds scan and reset on my Audi a3 2.0fsi 53 plate. The battery has run flat and I am having problems with power steering failure. I get 3 beeps and red steering wheel on start up. When driven for a few miles it clears and steering comes back. I have been advised that it could just need a scan and reset to rectify.
    Thank you for your time
    Clair
    27,126
    It should clear & not come back tbh if battery was flat, has the battery been checked & swapped out for new as yet.
    Jan 2014
    9
    Yes I've changed the battery and still the same
    27,126
    Then its had a fit & just needs recalibrating & errors cleared.
    See if N8 can help you out.
    Jan 2014
    9
    Thank you, I've sent him a message 😃
  1. VCDS for A8 in Cardiff area
    By wattsn in forum VCDS (formerly VAG-COM) forum
    Last Post: 24th August 2013, 22:45
  2. VCDS SCAN REQUIRED DEWSBURY/WAKEFIELD AREA
    By REDNERRAW72 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th May 2013, 13:13
  3. Anyone with VAGCOM (VCDS) in the West Midlands area?
    By Danman1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th May 2012, 11:16
  4. VCDS in coventry or midlands area
    By marcusd09 in forum VCDS (formerly VAG-COM) forum
    Last Post: 27th April 2012, 07:38
  5. Anyone got VCDS in the Telford/Shrewsbury area?
    By Agent_Trig in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th April 2011, 22:17
