Badger5AH Fabrications
    Jul 2013
    15
    vagcom dudley/Birmingham needed
    sent many pms to locals but no reply, I need someone to change the coding for my rear lights as I have changed to the genuine LEDs
    also to take the seat belt chime off
    l
    Jul 2013
    15
    any one?? willing to travel Wolverhampton Cannock walsal Birmingham maybe further if needed
    May 2013
    Birmingham
    212
    I have full VCDS and are based in Stourbridge I only tend to mess on my own car but if you are really stuck I'll give you a hand. Seat belt chime should be easy enough but do you have any info on what the process of coding the rear lights is? It's not something I've done so to save any hassle if you could find a guide or the steps required that would be beneficial!
    Jul 2013
    15
    hi. would be a big help if you could, I have full instructions on the rears lights and it looks pretty easy. I'm only about 10mins away from Stourbridge
    May 2012
    RETFORD, NOTTS
    1,753
    im in and out of wolverhampton a lot. happy to help out tomorow or thursday
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    Jul 2013
    15
    thanks to all that sent pms!! wallm0nkey is going to give it ago the weekend
  1. new to vagcom a3 8l need help please
    By bigwhitetruck in forum VCDS (formerly VAG-COM) forum
    Last Post: 26th March 2013, 22:07
  2. Vagcom in cumbria needed .thanks
    By Kelza in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th September 2011, 15:32
  3. Vagcom....Dudley West Midlands
    By Alan H in forum VCDS (formerly VAG-COM) forum
    Last Post: 18th September 2010, 17:22
  4. VagCom Faults, advice needed.
    By terrymcg in forum VCDS (formerly VAG-COM) forum
    Last Post: 7th February 2007, 19:45
  5. I might need someone with VAGCOM please!
    By chasdrury in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st September 2005, 10:36
