Sky InsuranceChris Nott
Results 1 to 13 of 13
    May 2013
    33
    Re enabling cruise issue
    Hi, I posted this in the A4 B7 posts and have had no replies please any info would be helpful.
    Morning All,
    I have fitted the cruise and dis stalks to my 2006 A4 avant s line with multi function steering wheel and with Mike Fosters help (thank you) we managed to enable the dis function and I earthed out pin one to get rid of the washer level warning which is great. The problem I have now is I can not enable the cruise, when I go into 01-engine then into coding II- 11 and put in the activation code 11463-cruise activation and then click DO IT an error message comes up saying,
    Login code not accepted by controller!
    You will have to turn the ignition off
    for a while before trying again.
    Error22: Conditions not correct or request sequence error.
    So not being a Vagcom guru i'm a bit stumped can anyone shed a bit of light on this for me as I've obviously missed a step out or have some thing missing.
    Also for info when I go into 16-steering wheel then into meas. blocks-08 I can see that the car and Vagcom can see the stalk is fitted because when I move the stalk it says cruise switch on or off then it says resume etc so it does see it.
    Cheers all,
    Jun 2011
    Great Melton Norfolk
    1,349
    does the long coding helper come up in VCDS? I was trying to code an A3 few weeks back and it wouldnot accept/change until I changed it in long coding helper.
    Nov 2013
    Heath Hayes
    951
    Not sure if this thread may provide some help.
    retrofit cruise control coding and activation issue
    Karl.
    Karls 312bhp A4 3.0 TDI build thread http://www.audi-sport.net/vb/audi-s4...ld-thread.html
    May 2013
    33
    Quote Originally Posted by gen.heinz guderian View Post
    Long coding is something I've not read up on much and what little bit I have makes me nervous cheers for the reply I will look into it
    May 2013
    33
    Quote Originally Posted by desertstorm View Post
    Karl.
    Cheers for the link I will have a look.
    Fossie
    Rhubarb Triangle
    3,969
    Quote Originally Posted by trickybusa View Post
    Long coding helper is what we used to change the steering module coding. As far as I can remember LCH did not appear in engine control module. However, we can have another look if you want.
    Have you got your own cable now ?
    2006 2.0L BKD 140 Sportback RHD ( manual, with extra bits incl. mfsw ) Gone
    2012 2.0L TDI Q3 S Line Quattro
    May 2013
    33
    Hi Mike, I've got the loan of a vag-com over Christmas. I thought long code was the longer codes that look more like e.99.ef.32.84 etc rather than the 11463 etc.
    Rick.
    Fossie
    Rhubarb Triangle
    3,969
    Rick.
    Hi Rick - the long coding helper appears when you click 'coding' in the
    control module. That then brings up all the information about the
    hexadecimal codes you refer to so that you can tick the relevant boxes like
    we did in steering module.
    As far as I can remember there is no 'coding' box in the engine module page.
    Did you check for the control cable ?
    Mike
    27,096
    If you ticked boxes in steering 16 on a B6/7, then that must be the wrong module as its short coding, not long coding for that module/chassis, so a digit change would be needed, not a tick in a box.
    Fossie
    Rhubarb Triangle
    3,969
    Sorry Nige - my bad. I didn't tick boxes in the steering module, I changed the numbers from 02002 to 02042 to change to 'with cruise control'.
    I was merely trying to help Rick by explaining the Long Coding Helper and how it describes the functions of the hexadecimal notations.
    My problem with his car is that the engine module will not accept the 11463 coding as he describes in his first post.
    Do I need to go somewhere else first to remove the cause of error 22 ? The current engine code is 0000072
    Feb 2014
    I have just fitted cruise control to my Audi A3 2.0 tfsi 2006.
    Can someone tell me where I can get it coded, 20 mile radius of Knutsford Cheshire if possible.
    Many Thanks
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,458
    Quote Originally Posted by marlon20 View Post
    Many Thanks
    Try a pm to user below. Welcome to audi-sport.net. x
    View Profile: Veneeringman - Audi-Sport.net
    Veneeringman's Avatar
    Bazinga
    Aug 2010
    Back in the UK
    638
    Quote Originally Posted by Sandra View Post
    Tis done.
    2012 Misano Red RS3 / Bucket seats Heated front & Rear / Aluminium Styling Pack / Bose / RNS-E / Bluetooth / Mobile phone prep low / AMI / Reversing Sensors / LED number plate lights / Led interior light pack / VCDS / Cruise Control / Exclusive Inlays / Auto Lights & Wipers / 8.5J fronts / extended leather / Michelin Pilot super sport tyres / and a few other things
  1. retrofit cruise control coding and activation issue
    By deian3387 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 1st August 2012, 18:58
  2. A3 8p Cruise Coding Issues.
    By Adam. in forum VCDS (formerly VAG-COM) forum
    Last Post: 19th March 2011, 17:56
  3. Cruise control fitting issue
    By Turkster in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 29th March 2010, 22:26
  4. Cruise Control Enabling
    By in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th June 2005, 00:36
  5. Cruise Control Enabling
    Last Post: 2nd June 2005, 16:39
