    Apr 2013
    6
    TPMS fault on an RS4
    Hi all,
    I have an intermittent fault on my B7 RS4 with the TPMS that comes up with the amber caution tyre light with a line through it. It comes up after around 10 miles of driving (sometimes more, sometimes less). I have connected up my VCDS (genuine cable + software) and it has come up with the following information:
    Wednesday,27,February,2013,18:30:05:30545
    VCDS Version: Release 11.11.5
    Address 65: Tire Pressure Labels: 8E0-907-273.lbl
    Control Module Part Number: 8E0 907 273 A HW: 8E0 907 273 A
    Component and/or Version: Reifendruck 3 H04 0130
    Software Coding: 0022523
    Work Shop Code: WSC 02197 785 00200
    VCID: 2A5D445D868878485F8
    1 Fault Found:
    01521 - Sensor for Tire Pressure
    004 - No Signal/Communication - Intermittent - MIL ON
    Freeze Frame:
    Fault Status: 10100100
    Fault Priority: 3
    Fault Frequency: 77
    Reset counter: 32
    Time Indication: 0
    Freeze Frame:
    (no units): 101.0
    Voltage: 13.60 V
    (no units): 61.0
    Not Recogn.
    Not Recogn.
    Not Recogn.
    Not Recogn.
    Is it possible to tell from this which wheel has the problem or do i need to do anything else to try and identify which wheel is giving the fault??
    Any help would be appreciated.
    Monkey
    P.S. If anyone in the Derby area needs to use my VCDS give me a shout
    Sep 2007
    North-East UK
    94
    Some details on the fault here: 01521 - Ross-Tech Wiki
    You need to refer to the Measuring Blocks to identify the faulty sensor.
    Steve
    MY2011 A1 TDI Sport
    Amalfi White, Sat Nav, Bose, Xenon Plus, Climate Control, Competition Line Trim, LED Interior Lights, Light & Rain Sensors, Polygon 18" Wheels. Retrofit Armrest, Cruise Control & Gauge Sweep. VCDS.
    Apr 2013
    6
    Thanks Steve. I'll give it a try tomorrow. Would I need to be driving the car so that I get the fault to come up?? Is there anything specific I should be looking for.
    thanks again
    Sep 2007
    North-East UK
    94
    Monkey
    The scan shows this is an intermittent fault, so you may not see the issue all of the time.
    There should be no need to drive the car, just have the ignition on and monitor the settings from each of the sensors. You may need to check a few times before finding the faulty unit. If driving helps to initiate the problem then try this out, but have someone else monitor the laptop!
    Steve
    MY2011 A1 TDI Sport
    Apr 2013
    6
    Excellent. Ill see how I get on. It's a shame that it doesn't tell you which tyre has the fault when it logs it
    cheers
    monkey
    Apr 2013
    6
    Think I've found the culprit. I Let down the tyres and refilled to find out which one was playing up. I think it is tyre number 4 which looks like it corresponds to what was stored in the fault history. Still got to road test to make 100% sure but I think I'm getting there. Thanks again for your help Steve :-)
  1. "56" plate RS4 Fault Codes
    By wuzie123 in forum RS4 Forum (B5 and B7 Chassis)
    Last Post: 18th August 2012, 23:05
  2. Looking for an RS4
    By FatBoy in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th November 2010, 16:35
  3. Unique RS4 for sale
    By Thorneyold in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st March 2003, 05:28
  4. RS4 power
    By DuncS3 in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th February 2003, 19:21
  5. Welcome to RS4 forums at audi-sport
    By Administrators in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th January 2003, 13:44
