Monkeys lips
Hi all,
I have an intermittent fault on my B7 RS4 with the TPMS that comes up with the amber caution tyre light with a line through it. It comes up after around 10 miles of driving (sometimes more, sometimes less). I have connected up my VCDS (genuine cable + software) and it has come up with the following information:
Wednesday,27,February,2013,18:30:05:30545
VCDS Version: Release 11.11.5
Address 65: Tire Pressure Labels: 8E0-907-273.lbl
Control Module Part Number: 8E0 907 273 A HW: 8E0 907 273 A
Component and/or Version: Reifendruck 3 H04 0130
Software Coding: 0022523
Work Shop Code: WSC 02197 785 00200
VCID: 2A5D445D868878485F8
1 Fault Found:
01521 - Sensor for Tire Pressure
004 - No Signal/Communication - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100100
Fault Priority: 3
Fault Frequency: 77
Reset counter: 32
Time Indication: 0
Freeze Frame:
(no units): 101.0
Voltage: 13.60 V
(no units): 61.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Is it possible to tell from this which wheel has the problem or do i need to do anything else to try and identify which wheel is giving the fault??
Any help would be appreciated.
Monkey
P.S. If anyone in the Derby area needs to use my VCDS give me a shout
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 77
Reset counter: 32
Time Indication: 0
Freeze Frame:
(no units): 101.0
Voltage: 13.60 V
(no units): 61.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Monkey
