AH FabricationsSky Insurance
Results 1 to 7 of 7
    pol
    Nov 2013
    16
    Thinking about getting vcds - some questions
    I have an airbag light I need to clear - I've been reading up on the probable cause of the faults which doesn't sound too difficult.
    I bought a cheapo cable - Yeah, sorry, it's been talked about to death on here, and have been trying to use VCDS lite but I get communication errors. No big surprise there I suppose. I just wanted to try it and have since read loads on buying the real deal.
    I am considering buying the proper cable from Nigel and the full software but I am wondering, I am I likely to run in to similar problems with communication errors? It'd be very annoying to spend that much and find out there's a problem with my car being read or something odd with my laptop.
    I'm going to try another laptop first and see if I can rule that out. I'm fairly sure it'll be the cheap lead but what makes the expensive one so much better? It's still the same concept, USB interface. What are the causes of communication errors? Interference from somewhere? I was hoping to see it connect well but just with limited software so I could get a taste for VCDS.
    Also, i'm using a Mac, dual booted with Windows 8 so it's not running through a VM or anything. I've tried tinkering with the com port settings but any sort of scan results in 'too many communication errors to continue'. I don't think it being a Mac would have anything to do with it as it is basically just an intel based pc underneath.
    So basically, sell me the proper lead and software! I'd pay for reliability if it is going to give that.
    Also, It looks like I may need to find a replacement instrument cluster at some point. I've been reading up on programming one from another car to work in mine. I hear you need a code but some second hand ones I've looked at don't come with a code.
    Can you obtain the pin / code from a used instrument cluster and get it to work in another car? If so, how?
    I'd like to get handy with the VCDS software as it sounds like it could save me some money in future.
    Thanks,
    Paul
    Nov 2013
    Heath Hayes
    948
    Windows 8 will pretty much be your problem. How old is your car? what model ?
    Karl.
    pol
    Nov 2013
    16
    Quote Originally Posted by desertstorm View Post
    Karl.
    Hi Karl,
    Ah, ok, I read it was compatible but to be honest, I'll use whatever version works best with VCDS. Windows XP will be unsupported soon I suppose, so which Windows version is best? 7?
    It is an A3, 1999
    May 2012
    RETFORD, NOTTS
    1,753
    I use XP. I have used vista, 7 and 8 no issues.
    For just a cluster swap its a lot of tool to buy, but if your a DIYer its worth its wieght in gold imo.
    Comms issues could be caused by anything but usually you can figure it out with some thinking and vcds.
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    pol
    Nov 2013
    16
    Quote Originally Posted by @udi A3 View Post
    That's why I wanted to try VCDS lite first... Is a cluster swap possible on the lite version, assuming there are no comms issues?
    The cluster and airbag light will be just the start I'm sure. I'm a fairly keen DIY'er when I can be arsed and because the car is a new toy, I'm still in to tinkering with it.
    Just trying to get an old XP laptop installed now.
    So can you still get comms issues on the full VCDS with the posh cable? I don't doubt that it's as valuable a tool as people say but I need to know if it will work better on my laptop and car I suppose.
    Also, does anyone else use a dual booted Macbook?
    May 2012
    RETFORD, NOTTS
    1,753
    Ross-Tech: VCDS: Function Table
    Im going to say no. Adaptions and security access are limited even when registering the lite version. Looks like full or nothing.
    pol
    Nov 2013
    16
    For info, the 1st cable I bought was at fault. I got a full refund. This is the ebay item: VAG GROUP USB COM PORT OBD2 II KKL ECU DIAGNOSTIC CABLE LEAD VCDS-LITE 409 | eBay
    Yes, it was refunded with no quibble but it is not worth the headache. The connector is also a poor fit.
    I bought the £20 one from Gendan who assured me all of their cables are tested by them. It works fine with VCDS lite and from there I can decide if I need the registered VCDS lite or the full version.
  1. Thinking about getting an S3
    By Escy in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th February 2012, 23:39
  2. Thinking about getting an S3 again :)
    By vrbob in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th July 2011, 15:00
  3. Thinking about getting rns-e
    By ru4shaw in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th December 2009, 22:39
  4. thinking about getting a.........
    By a4quat in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th May 2007, 15:25
  5. Thinking about getting an S3, shock horror LOL. A few Qs
    By Markb in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th September 2006, 20:29
