Volks AutosAH Fabrications
Thread: VCDS and DPF
    A5sprint's Avatar
    Feb 2013
    Lowestoft, UK
    57
    Question VCDS and DPF
    Hi all,
    Does anyone know if there is a way of checking the current soot load level of the DPF using VCDS? I have looked on the Ross-Tech site and searched on here but can't find how to check this, only how to do a regen.
    I would like to periodically see what the level is before any problems arise.
    2008 S5 Coupe in Ibis White with 20" 7 twin-spoke Speedline Alloys, Red Leather, Sat Nav, B&O Sound, Red Ambient Lighting.
    Nov 2013
    Heath Hayes
    951
    Login to the ECU and select Advanced measuring blocks. There are about several hundred possible measurents available, there are calculated soot loads and actual differential pressure readings that give you an indication of the state of the DPF. Also counters that tell you how many Km the car has done since the last regen etc.
    Karl.
    A5sprint's Avatar
    Feb 2013
    Lowestoft, UK
    57
    Quote Originally Posted by desertstorm View Post
    Karl.
    Thanks for that Karl, I'll check that out.
    Mar 2013
    Southampton
    128
    Hi,
    If you look at the Ross Tech site on the DPF regen page all the info is there, it states that the DPF soot level is shown on MVB 075 box 3.
    Though my specific engine code was not listed on the DPF site I looked at the MVBs and they were right for my engine as well.
    A5sprint's Avatar
    Feb 2013
    Lowestoft, UK
    57
    Thanks for that Andy
  1. Replies: 5
    Last Post: 17th October 2011, 07:38
  2. MOT changes 2012 - Chips and DPFs, response from VOSA
    By jrsteeve in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th September 2011, 21:21
  3. Help with vcds and checking aircon
    By markie A3 in forum Air Conditioning
    Last Post: 8th April 2011, 22:00
  4. 140's/170's and DPF
    By MarkRobinson in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st July 2010, 11:00
