Chris NottEM Tuning
    Nov 2013
    61
    Browsing the coding options in VCDS
    I've been browsing the controller codings with VCDS and noticed a few anomalies I was wondering if anyone can shed some light on?
    In controller 02 - Auto Transmission I note that Byte 1 Bit 4 in mine (Steering Wheel TipTronic Buttons Installed) is not checked but they are installed and fully functional. Any ideas why the Bit is not selected?
    In controller 10 - Park / Steer Assist Byte 1 Bit 4-7 00Variant:Left hand drive is selected even though it's RHD. Again, any ideas why this would be the case?
    27,099
    Is your cable genuine, if so, submit these queries to support@ross-tech.com so they can look at it as a bug potentially.
    Nov 2013
    61
    Yeah it's genuine, purchased from Gendan. I hadn't considered that it could be a bug. I'll contact Ross-tech and let you know what they say.
    Nov 2013
    61
    Well, I've been on to Ross-Tech and they've asked for a scan which I've sent so I'm waiting on another reply. Update to follow.
    One thing they did sort for me though was a connection issue I was having because I ran win 7 through VMWare Fusion on a mac (try to avoid doing this if you can as the system becomes too slow). I've now switched to my Windows laptop and connection is no longer an issue.
    May 2012
    RETFORD, NOTTS
    1,753
    I often get things like this. Ill have to bombard them with emails! Generally if the coding appears wrong but the function works as it should i leave it as it is.
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
  1. Replies: 4
    Last Post: 15th May 2013, 16:00
  2. Major VCDS Help, I changed the coding i should not have!
    By johal87 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th January 2011, 17:31
  3. Whats the best option to sell my car.
    By A4 TC in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th March 2008, 12:26
  4. Replies: 2
    Last Post: 10th April 2007, 18:13
  5. Name the one option you wish you had..?
    By silver75 in forum General Chat
    Last Post: 14th December 2006, 09:01
