Results 1 to 7 of 7
    paul26982's Avatar
    Aug 2009
    north east U.K
    1,275
    B6 ABS Module Question
    Audi A4 B6 - 3.0 V6 ASN
    I have a replacement module i want to fit. its the same part numbers etc as the current what is fitted.
    Is it a matter of plug and play / OR log into VCDS go into ABS and then adapt / Or does it need coding but surely not as the car is K Line and not CAN
    2003 B6 Audi A4 Avant. 3.0 V6 Quattro Sport
    Jul 2007
    London
    3,086
    DId it came of a identical car ? If it did then it might not need coding, however most cases they do require coding as there are different pr numbers !
    FOR SALE:
    paul26982's Avatar
    Aug 2009
    north east U.K
    1,275
    Came of an identical car. All the nbers match my current pump etc too
    paul26982's Avatar
    Aug 2009
    north east U.K
    1,275
    Any body with any info ?
    paul26982's Avatar
    Aug 2009
    north east U.K
    1,275
    WOW didnt think this would of been that hard of a question
    Jul 2007
    London
    3,086
    put it on, if it works out of the box then you're lucky...
    FOR SALE:
    Mar 2013
    Southampton
    125
    I think you will need to code it, I have recently had to do it on my 2005 A4 S4 Cab, as I fitted cruise control and had to replace the steering control module, I followed the video on the bottom of this web page as well as the instructions in the RT Wiki which talks you through the whole process and how to establish the codes you need,
    http://wiki.ross-tech.com/wiki/index...ics_(Bosch_5.7)
  1. ABS module wiring diagram, module question
    By boost-addict in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd October 2012, 10:39
  2. abs module diy fix?
    By ian52 in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th December 2008, 22:08
  3. abs module problem
    Last Post: 26th October 2008, 09:06
  4. ABS Module
    By c16wko in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd March 2008, 20:26
  5. ABS modulator
    By jayne in forum Classic Audi Forum
    Last Post: 13th September 2007, 18:10
