    Oct 2010
    6
    TV Tuner and Aerial Faults
    I have just got VCDS and did an auto scan on my Audi S3 8P (57 Reg) and it found the following:
    VIN: WAUZZZ8P48A019706
    19-CAN Gateway -- Status: Malfunction 0010
    37-Navigation -- Status: Malfunction 0010
    56-Radio -- Status: Malfunction 0010
    57-TV Tuner -- Status: Cannot be reached 1100
    Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
    Part No SW: 1K0 907 530 L HW: 1K0 907 951
    Component: J533__Gateway H15 0180
    Revision: H15 Serial number: 1400K07613838D
    Coding: E9831F0EC006020101
    Shop #: WSC 01211 210 01000
    VCID: 30697732A3552E9E243-8065
    1 Fault Found:
    00467 - TV Tuner (R78)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 2
    Fault Frequency: 254
    Reset counter: 7
    Mileage: 79417 km
    Time Indication: 0
    Date: 2013.11.04
    Time: 14:22:09
    Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
    Part No SW: 8P0 035 192 S HW: 8P0 035 192 S
    Component: RNS-E HIGH EU H77 0650
    Revision: 04S Serial number: AUZBZ9S0874A51
    Coding: 0209718
    Shop #: WSC 00000 781 01234
    VCID: 3F8B240E6E0BC1E6AD9-806A
    2 Faults Found:
    00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
    007 - Short to Ground
    Freeze Frame:
    Fault Status: 01100111
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 243
    Mileage: 79417 km
    Time Indication: 0
    Date: 2013.11.04
    Time: 14:22:23
    Freeze Frame:
    Mileage: 79410 km
    Count: 411
    Clock: 14:22
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 7
    Reset counter: 7
    Mileage: 79417 km
    Time Indication: 0
    Date: 2013.11.04
    Time: 14:22:36
    Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
    Coding: 0209718
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 243
    Mileage: 79417 km
    Time Indication: 0
    Date: 2013.11.04
    Time: 14:22:23
    Freeze Frame:
    Mileage: 79410 km
    Count: 411
    Clock: 14:22
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 7
    Reset counter: 7
    Mileage: 79417 km
    Time Indication: 0
    Date: 2013.11.04
    Time: 14:22:36
    Address 57: TV Tuner
    Cannot be reached
    My car has a RNS-E but I have found out it was a retrofit by a previous owner.
    Regarding the fault ‘00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier.’ Is this the common fault that can be fixed by changing the rear aerial amps? Or is this a different issue as I do seem to get poor radio signal in some areas.
    The other faults regarding the TV Tuner. As far as I know my car doesn’t have a TV Tuner so does this mean my car hasn’t been coded properly? If this is the case how do I go about coding it properly so these faults go away?
    27,093
    Hey Rob
    Just remove Tuner from the 19 gateway coding & also from 37 navigation.
    As it was a retrofit & as you had a 2+ unit in before, then yes the antenna upgrade should fix this, if you need that work completed, give us a shout.
  1. OBD Port location and engine fault diagnosis
    By vadhert in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th April 2010, 09:31
  2. pedals and aerial
    By s3 man in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th February 2010, 12:10
  3. Radio/Aerial Fault
    By regor in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th November 2009, 14:09
  4. tv tuner and navi wiring!!
    By Mcgough in forum In-Car Entertainment
    Last Post: 27th April 2007, 18:59
  5. limp mode and abs fault
    By smith4130 in forum Diesel forum
    Last Post: 12th March 2007, 22:50
