Chris NottSky Insurance
    Crunching The Gears
    Apr 2012
    Invergordon Scotland
    406
    ABS/ESP fault scan inside help needed.
    HI after some help with this scan
    1. the ESP fault, is it a big issue
    2. the heated seat 'problem' seat still gets hot so don't know what the problem really is
    any help would be good thanks
    Corey
    VCDS Version: Release 12.12.0 (x64)
    Data version: 20130910
    Monday,11,November,2013,16:48:11:18744
    Chassis Type: 8P (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56
    VIN: WAUZZZ8P97A223304 Mileage: 107110km/66555miles
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: Malfunction 0010
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: Malfunction 0010
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    Address 01: Engine Labels: 03C-906-056-BAG.lbl
    Part No SW: 03C 906 056 ED HW: Hardware No
    Component: MED9.5.10 G00 0236
    Revision: 66H09--- Serial number: AUX7Z0G4FN70D3
    Coding: 0000072
    Shop #: WSC 06314 000 00000
    VCID: 69DFF8934030DA5623D-803C
    No fault code found.
    Readiness: 0000 0000
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
    Component: ESP FRONT MK60 0101
    Revision: 00H11001
    Coding: 0019074
    VCID: 73E39AFB12FC1086991-8026
    1 Fault Found:
    00290 - ABS Wheel Speed Sensor; Rear Left (G46)
    003 - Mechanical Failure - Intermittent
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 AD HW: 8P0 820 043 AD
    Component: KlimavollautomatH19 0360
    Revision: 078503 Serial number: 8P0820043AD
    Shop #: WSC 00000 000 00000
    VCID: 6ED58B8F79DE3D6E76F-803B
    Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
    Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
    Component: Bordnetz-SG H43 1201
    Revision: 00H43000 Serial number: 00000007067309
    Coding: A58CCF27A014100000000000000000000009FE175C0100
    Shop #: WSC 06314 123 08192
    VCID: 4089053713CAFB1ED43-8015
    Subsystem 1 - Part No: 8P2 955 119 E Labels: 1KX-955-119.CLB
    Component: Wischer AU350 H01 0130
    Coding: 00062736
    Shop #: WSC 06314
    1 Fault Found:
    02092 - Enabling Heated Seat
    009 - Open or Short to Ground
    Freeze Frame:
    Fault Status: 01101001
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 234
    Mileage: 106952 km
    Time Indication: 0
    Date: 2013.11.09
    Time: 16:16:00
    Freeze Frame:
    ON
    Voltage: 14.00 V
    ON
    ON
    OFF
    OFF
    OFF
    Address 15: Airbags Labels: 8P0-959-655-94.lbl
    Part No SW: 8P0 959 655 H HW: 8P0 959 655 H
    Component: Airbag 9.41 H13 4220
    Revision: 91H13422 Serial number: 0037W0G1J8LL
    Coding: 0071612
    VCID: 479B1E2B36E4CC26159-8012
    Subsystem 1 - Serial number: 63328RB4026F4BC3V
    Subsystem 2 - Serial number: 63428RB402698CFD1
    Subsystem 3 - Serial number: 63528RB4026F4BCE1
    Subsystem 4 - Serial number: 63628RB402698D2F-
    Subsystem 5 - Serial number: 63729RB402667631E
    Subsystem 6 - Serial number: 63829RB4026676B7T
    Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
    Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
    Component: J0527 H36 0070
    Coding: 0002042
    VCID: 418F003318C0F216DBD-8014
    Subsystem 1 - Part No: XXXXXXXXXXX
    Component: E0221 H02 0100
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
    Part No SW: 8P0 920 981 G HW: 8P0 920 981 G
    Component: KOMBIINSTR. VDO H20 0570
    Revision: D0H20004 Serial number: 2244G004006249
    Coding: 0004418
    Shop #: WSC 06529 000 1048576
    VCID: 3C7171C77F229FFE88B-8069
    Address 19: CAN Gateway Labels: 1K0-907-530-V2.clb
    Part No SW: 1K0 907 530 K HW: 1K0 907 951
    Component: J533__Gateway H12 0170
    Revision: H12 Serial number: 330010742003FC
    Coding: 3D0F034207000101
    Shop #: WSC 06314 123 12345
    VCID: 2F6B568BBE5474663D9-807A
    1 Fault Found:
    02649 - Digital Radio Tuner
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 154
    Mileage: 104665 km
    Time Indication: 0
    Date: 2013.10.10
    Time: 18:55:40
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Revision: D0H20004 Serial number: AUX7Z0G4FN70D3
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN2.lbl
    Part No: 8P0 959 801 H
    Component: Tuer-SG 020 0090
    Coding: 0000624
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K2 909 144 L
    Component: EPS_ZFLS Kl.078 H07 1806
    Shop #: WSC 02069 000 90108
    VCID: 356764E35C084EB6775-8060
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433 F
    Component: KSG H05 0070
    Coding: 9880202002586D298505489AC637
    VCID: 3F8B06CB6E3484E6AD9-806A
    Subsystem 1 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Subsystem 2 - Part No: 1K0 907 719 C
    Component: Neigungssensor 005 0003
    Subsystem 3 - Part No: 8P0 951 177
    Component: Innenraumueberw.H04 0020
    1 Fault Found:
    00352 - Terminal 30A
    011 - Open Circuit
    Address 47: Sound System Labels: 8Px-035-382.lbl
    Part No SW: 8P3 035 382 HW: 8P3 035 382
    Component: AB2 SUBWOOFERBOXH27 0160
    Revision: 00005 Serial number: 30659635803312
    VCID: F0E915F7E3EAAB9EE43-80A5
    Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN2.lbl
    Part No: 8P0 959 802 H
    Coding: 0000624
    Address 56: Radio Labels: 8J0-035-1xx-56.clb
    Part No SW: 8P0 035 195 G HW: 8P0 035 195 G
    Component: R Symphony2+ H15 0240
    Revision: 00H15000 Serial number: AUZ1Z4G9063813
    Coding: 0010111
    VCID: 366563EF410E45AE7EF-8063
    1 Fault Found:
    00821 - Antenna 2 for Radio (R93)
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 5
    Fault Frequency: 21
    Reset counter: 228
    Mileage: 104665 km
    Time Indication: 0
    Date: 2013.10.10
    Time: 19:01:42
    Mods so far...
    LED Interior Lights, Front splitter, Cruise Control.
    Puddle/ Footwell Lights, LED number plate and side lights.
    75% Window Tints, MY11 Lights, Black Optics Grill.
    MFSW, Leather trimmed Grab Handles. CH/LH Lights
    JL Audio, DAB radio
    Vinyl wrap wing mirrors
    27,072
    I would say someone's been playing with coding
    Just decode the heated seats from 09, remove digital radio from gateway 19, try to clear antenna fault from radio 56 & clean the rear abs sensor/connector, if still comes back then replace.
    Crunching The Gears
    Apr 2012
    406
    Only a little bit haha.
    Decode?? Checky I do have heated seats honest.
    ok will do that for the digital radio, the other antenna 2 fault is because I have the AutoDab installed.
    will do that with the ABS. Ill let u know how I get on.
    cheers
    Mods so far...
    JL Audio, DAB radio
    27,072
    Yeah on 8p, module 09 usually has nothing to do with heated seats, so disable it & see if it goes away & seats still work
  1. HELP!! ABS/ESP, PARKING BRAKE FAULT AND HEADLIGHT RANGE CONTROL DEFECTIVE!!
    By chrisy t in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 24th October 2013, 21:54
  2. Audi A3 2002 PD MOT Fail help needed. no ABS or ESP light on ignition on.
    By skydivebaz in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th September 2013, 21:59
  3. HELP! rear wheel bearing wrong size ? abs + esp fault
    By _scotty_ in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th February 2013, 20:48
  4. Urgent Help Needed! ESP Fault
    By hilljsr in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th February 2010, 00:38
  5. misfiring fault, tech help needed - have vagcom fault codes
    By shufti in forum General Technical / How To
    Last Post: 16th June 2006, 22:14
