Results 1 to 7 of 7
    Oct 2013
    Reset the central convienance module
    Just got a A3 8Pa and was wondering if I can reset the central convienance module.
    Currently set to have selective locking, auto lock. But the auto unlock when you pull the key out of the ignition does not work.
    26,716
    Do you have a genuine interface to recode with?
    Oct 2013
    Brother-in-law does
    26,716
    Well depending on the year, either recode via vcds or set within the dis.
    Oct 2013
    Car don't have DIS. It's a 2005 model 1.9 tdi SE 5speed manual A3 sportback. Although DIS is a thought. Do you need to get any specific type of instrument cluster? Between certain years and wether it's petrol or diesel?
    26,716
    VCDS it is then.
    Yes it has to be a specific type, requires immo coding & mileage corrected, we offer these installed, but not cheap at all & we only do in the south east due to immo systems.
    Oct 2013
    So how do you go about sorting the auto unlock with vcds? Links on wiki Ross tech are abit vague. Text is missing
  1. Resetting The low oil warning light.
    By Biggles in forum General Technical / How To
    Last Post: 19th January 2007, 09:08
  2. resetting the service reminder?
    By W8 Performance in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd March 2006, 17:02
  3. Do I need to reset the ECU???
    By imported_razputin in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th February 2005, 08:13
  4. Resetting the ECU
    By robthehungrymonkey in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th May 2004, 11:13
