AH FabricationsChris Nott
    DGT
    Jul 2010
    21
    07 B7 2.0tdi boost fault, code help needed please
    Any ideas greatly appreciated.
    Intermittent limp mode, flashing glow plug light, loss of boost then sudden boost, strange noise from intake near front when engine stopped.
    Address 01: Engine Labels: 03G-906-018-BRD.clb
    Control Module Part Number: 03G 906 018 AQ HW: 03G 906 018 AQ
    Component and/or Version: R4 2.0l PPD1.3 G 9971
    Software Coding: 0000072
    Work Shop Code: WSC 00636 210 90493
    VCID: 74EC6BBA176C39BE9BD
    1 Fault Found
    000665 - Boost Pressure Regulation
    P0299 - 006 - Control Range Not Reached - Intermittent
    Freeze Frame
    Fault Status: 00000001
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 34
    Mileage: 0 km
    Time Indication: 0
    Freeze Frame
    RPM: 2144 /min
    Torque: 256.0 Nm
    Speed: 115.0 km/h
    74.49 %
    Voltage: 14.13 V
    Pressure: 2257.8 mbar
    Pressure: 1405.8 mbar
    27,072
    Sounds like a boost leak to me, that's a fair bit of the requested & actual boost numbers.
    DGT
    Jul 2010
    21
    Thanks, ill check hoses etc
  1. Got few fault codes, help needed please as new to VCDS
    By JMB-S3 in forum VCDS (formerly VAG-COM) forum
    Last Post: 13th May 2014, 15:43
  2. fault codes help needed!
    By zornyan in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th May 2013, 19:30
  3. fault codes help needed
    By Sham101 in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th May 2013, 21:27
  4. Fault code help needed 2000 S3
    By fitzdog88 in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th April 2012, 22:17
  5. Fault code help needed plz!!!
    By shaz-raul in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 31st January 2010, 17:41
