AH FabricationsChris Nott
    Apr 2013
    35
    2012 A3 1.6 tdi ABS module coding
    Is there somewhere online that I can find the coding for this car/unit?
    my car keeps showing brake warning.
    i believe it's down to having had the module replaced, but not coded (or not coded correctly!!!)
    27,126
    Do you have a genuine vcds?
    Hold on, its a 2012 A3, why are you messing with it, its under warranty so audi should of resolved any coding for this for you, take the car in.
    Apr 2013
    35
    I sent you a message about this. Thanks.
  1. ABS Module code
    By deejames in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th July 2013, 21:28
  2. ESP/ABS Error Code
    By Boydave in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd July 2013, 15:52
  3. Replies: 4
    Last Post: 15th May 2013, 16:00
  4. ABS module won't code with VCDS???
    By BILKO1 in forum VCDS (formerly VAG-COM) forum
    Last Post: 4th February 2011, 07:01
  5. Cheaper TDi tuning modules, anyone used one?
    By Nessy in forum Diesel forum
    Last Post: 4th May 2006, 17:34
Tags for this Thread
