Results 1 to 11 of 11
    Sep 2013
    Heysham and Catterick
    24
    Fault code help please
    Hi everyone,
    I've read my fault codes on my car after my ESP light came on the dash and will not turn off, these are the fault codes 00810, 00778 and 01423 and I've not had the steering wheel off and I've just had all my geometry put back into line any help would be appreciated.
    Jun 2011
    Great Melton Norfolk
    1,340
    can you post the complete scan, what code reader did you use?
    Sep 2013
    24
    It was just a generic code reader and just give the numbers
    Jun 2011
    1,340
    Sep 2013
    24
    Surely 3 sensors ain't gone at the same time they all say no or incorrect basic settings/adaptation
    Apr 2013
    Aberdeenshire
    584
    Quote Originally Posted by Miked6405 View Post
    Have you disconnected your battery or was it flat ? As esp and angle sensor come up but clear once you drive
    Sep 2013
    24
    Yeah I took out the injectors and when trying to bleed the fuel the batts went flat then the light came on and stayed on since
    Jan 2012
    1,599
    Did you do a full lock-to-lock on the steering wheel and go a short drive?
    Sep 2013
    24
    Not at the time ill have a go at it in a bit and keep post updated
    Sep 2013
    24
    Still no joy think ill try get the basic settings re done, anyone with the cable in lancaster area?
    Sep 2013
    24
    Hi got the cable from NHN cheers Nigel and completed the basic settings all good now cheers for all your help in this matter everyone
  1. fault code help please
    By brys3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th June 2010, 19:59
  2. VAG COM fault codes - help please?
    By Geeman in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th June 2009, 08:54
  3. 2.8 Fault code help please
    By stapo69 in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th January 2009, 20:54
  4. FAULT CODE HELP PLEASE
    By 1wheelonly in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th November 2008, 07:14
  5. FAULT CODE HELP PLEASE
    By 1wheelonly in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th November 2008, 18:31
