Ecu plugged had suffered heavy water damage, I wouldnt know where to begin with testing the wiring for shorts further up the loom.
Old ecu would not allow the throttle body alignment. Assume drivers damaged due to water damage.
New ecu adapted, TBA completed, no error codes stored with VCDS.
Battery voltage good, spark good.
If the engine is flooded it would start today. Another way to start a flooded engine is remove all leads and push them on so they only just touch the plugs but dont clip on them. (not sure why this works).
Also try removing cam belt cover to check cams turn when cranking.
I suspect there is another damaged sensor/actuator caused by the water.
Im sorry I dont know enough about petrol engine management to help you further
Here are the extracts from the initial VCDS log, all codes were cleared, even after failing to start, but as i said, somethine may come back when it starts, feel free to pop round on the way to work.
Tuesday,24,September,2013,15:08:16:05185
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: License Plate:
Mileage: 228810km-142175mi Repair Order: REMY
Chassis Type: 8D - Audi A4 B5 (1995 > 2001)
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
Mileage: 228810km/142175miles
Address 01: Engine Labels: None
Part No: 3B0 907 552 J
Component: 2.4L V6/5V 0001
Coding: 04051
Shop #: WSC 06315
VCID: 2B55B967D9117146111-5140
5 Faults Found:
17987 - Throttle Actuator (J338)
P1579 - 35-10 - Adaptation Not Started - Intermittent
17951 - Angle Sensor 1 for Throttle Actuator (G187)
P1543 - 35-00 - Signal too Small
17580 - Angle Sensor 2 for Throttle Actuator (G188) Signal too Low
P1172 - 35-00 -
17746 - Camshaft Position Sensor (G40)
P1338 - 35-00 - Open or Short to Plus
17967 - Throttle Body (J338)
P1559 - 35-00 - Fault in basic settings
Readiness: 0000 0000
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 8D0 927 156 BA
Component: AG5 01V 2.4l5V RdW 2526
Coding: 00003
Shop #: WSC 06315
VCID: 6DD1777F2785BF764F5-5140
2 Faults Found:
18258 - Powertrain Data Bus
P1850 - 35-10 - Missing Message from ECU - Intermittent
18265 - Load Signal
P1857 - 35-00 - Error Message from ECU
Address 03: ABS Brakes Labels: 8E0-614-111-ABS.lbl
Part No: 8E0 614 111 AB
Component: ABS 5.3 FRONT D00
Shop #: BB 24548
VCID: 5EB320B3DA23D4EEC6F-5140
No fault code found.
Address 08: Auto HVAC Labels: 8D0-820-043-1D.lbl
Part No: 8D0 820 043 M
Component: A4 KLIMAAUTOMAT D53
Coding: 00061
Shop #: WSC 06315
VCID: 2A5BBC63D6EB684EEA7-258E
Address 15: Airbags Labels: 8D0-959-655-AI8.lbl
Part No: 8D0 959 655 F
Component: Airbag Front+Kopf 0001
Coding: 00304
Shop #: WSC 06315
VCID: 3979932F234DD3D693D-515E
Address 17: Instruments Labels: 8D0-919-xxx-17.lbl
Part No: 8D0 919 910 S
Component: B5-KOMBIINSTR. VDO D15
Coding: 00462
Shop #: WSC 00000
VCID: 3C778A3B2C7FE6FE88B-5140
Subsystem 1 - Part No: IMMO
Component: IDENTNR: AUZ7Z0W0855609
IMMO-IDENTNR: AUZ7Z0W0855609
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8D0 862 257 E
Component: CV-Pump, Alarm, RC D13
Coding: 13130
Shop #: WSC 06315
VCID: 2F6DAD77ED090D663D9-4F06
11 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
00991 - Interior Lights
28-00 - Short to Plus
00955 - Key 1
09-00 - Adaptation Limit Surpassed
00956 - Key 2
01134 - Alarm Horn (H12)
76-00 - Terminal 30 missing
49-00 - No Communications
Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00101
Shop #: WSC 06435
VCID: E0CF9E4B6057621E743-4B50
1 Fault Found:
01383 - Alarm triggered by Anti-Theft Sensor; Front Right
35-00 - -
Address 56: Radio Labels: 8D0-035-1xx-56.lbl
Part No: 4B0 035 186
Component: Radio 0001
Coding: 00201
Shop #: WSC 06315
VCID: DDB1A7BF57254FF65F5-4B04
1 Fault Found:
65535 - Internal Control Module Memory Error
00-00 - -
Address 76: Park Assist Labels: 4B0-919-283.lbl
Part No: 4B0 919 283
Component: Parkingsystem A4 RDW D18
Coding: 01104
Shop #: WSC 06315
VCID: E6C3885382730C2E8EF-51B6
