Can I disable the auto lock feature on my A3 using VCDS? The one where after a certain while the car locks automatically if you don't lock it manually? Thanks
Yes.
was the baby driving ?
as it dont lock till your doing above 1o mph
only auto lock i know of is
if you unlock the car and dont open a door then it locks itself after so long
then the one where you drive away and it locks above 10mph
Thanks, which option? any guide? please post or PM me if you know anything more. ThanksSolution is to decode the option with vcds.
My Wifes mk4 Golf auto locks again if you open door and close it without turning ignition on.
But how to physically turn this feature off completely? must be a coding within a ecu that can be changed/edit/adjusted to stop this feature?In this case I can say for sure that this is actually a fault. Yes the MK4 Golf will auto lock if you unlock it and don't touch it, it will lock itself again. However if you open a door it should cancel the auto lock if behaving normally, to attempt to prevent you from locking your keys in the car. If it still auto locks after you've opened and closed a door its because your car has a faulty door lock module, its a very common fault as these cars are 13+ years old and the module's are prone to dry solder joints..
You can code out the anti hi-jack auto locking that locks after a certain speed, but I've never tried to code out the auto lock for when you lock the car but don't open any door.
