Badger5JMB Retrofits
    benjie's Avatar
    Oct 2009
    Swindon - home of the 'Magic' Roundabout.
    635
    Help interpreting a code please.
    My car's a B6 A4.
    My ECON light came on on the air con panel the other day & won't go off. I scanned the car and it came up with:
    00819 - High Pressure Sensor (G65)
    16-10 - Signal Outside Specifications - Intermittent
    My question is: Is it as easy as replacing the sensor? When a sensor or something fails, it normally says "Short to plus" or something similar. But now it says "Signal outside specification." I'm thinking that maybe, the signal is outside specification due to something else in the HVAC system not working properly (something that isn't monitored by the car), and this causes the readings of the G65 sensor to be out of range and store the fault code/prevent the air-con from working? There are no other fault codes (except for an aerial one in Nav/Radio).
    Does anyone have any advice?
    B8 S4 Avant in Misano Red with some lovely toys!
    Prev: B6 A4 Saloon 1.9 TDI quattro Sport - great car.
    27,073
    Its fixed to the compressor silver piping usually, cant recall where on the B6, but it screws of iirc 17mm spanner, they do go eventually, be careful not to damage the piping whilst swapping.
    benjie's Avatar
    Oct 2009
    635
    Thanks Nigel, it's near the passenger headlight. Do you reckon it's gone then - or is it something else causing it to give crazy readings and throw a fault?
    27,073
    I've replaced a number of them & tbh its cheaper than allot of other things, fact econ light wont go out is one hint of G65 fault, I cant be 100% sure, but fault log of G65 & econ, for me replace it & see what happens.
    benjie's Avatar
    Oct 2009
    635
    OK thanks, I appreciate yhour advice. I'll get it changed, it's not tnhat expensive or a particularly time consuming job.
  1. help with fault code please p1847 18255 A3 2.0 TDI 140 BHP REG JULY 2005
    By adiehorrocks in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th August 2011, 21:20
  2. Help with fault codes please - Update : new problem found + video
    By J_V_DUB in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th July 2011, 09:26
  3. New user to vag-com, help on fault codes please
    By Hightower in forum VCDS (formerly VAG-COM) forum
    Last Post: 14th December 2009, 09:04
  4. Need help with Fault codes please
    By xlr8 in forum VCDS (formerly VAG-COM) forum
    Last Post: 10th August 2007, 22:57
  5. Help with this code please...
    By terrymcg in forum VCDS (formerly VAG-COM) forum
    Last Post: 2nd July 2007, 17:28
