Like Tree1Likes
  • 1 Post By Dan_Mol
Thread: Audi A3 - 2.0 TFSI Error codes and rough idle.
    Jul 2013
    44
    004759 - Pressure drop between turbo and throttle valve - (Check DV.)
    P1297
    004244 - Bank 2; Fuel measuring system 2.
    P1094
    001300 - Sensor for battery temperature.
    P0514
    Checked fuel pressure as per Ross-tech wiki but not a clue what figures should be compared to figures I have.
    Anyone got any ideas, car has a very lumpy idle, this has only happened since leaving work tonight. Other than the idle it drives fine, don't want to drive too far tho incase I'm causing more damage.
    First thought was a coil pack, but any gone on previous cars all go under load and this is fine.
    Jul 2013
    44
    Cleared the errors and only the 1st error comes back on idle. Had the engine cover / airbox off to check for split hoses. I also checked the PCV by opening the oil cap with engine running, a suck and release of air suggest PCV so going to swap that tomorrow as symptoms seem similar from online faults.
    Jul 2013
    44
    Changed the PCV valve and gasket today £51 from TPS and appears to be solved, cleared errors, test drive and still no errors so all good.
    PCV Valve - 06F 129 101 N (Is a revision P but doesn't work on older stuff)
    PCV Gasket - 06F 103 483 E
    sliced likes this.
  1. Error Codes and general advice
    By Steve Welch in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th July 2013, 12:54
  2. 2007 B7 S4 Error codes and problem
    By ricostuart in forum VCDS (formerly VAG-COM) forum
    Last Post: 19th February 2013, 12:53
  3. Error codes p3105 and p19561
    By vinnyl in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 23rd October 2009, 12:23
  4. Help with error codes P1103, P0139 and P0411
    By royster in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th September 2007, 22:12
  5. error code 00575, and sqealing noise
    By lowrider786 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th July 2005, 23:38
