Paul @ Unit 9 Remaps
- Joined
- Aug 10, 2009
- Messages
- 2,015
- Reaction score
- 131
- Points
- 63
- Location
- north east U.K
- Website
- www.unit9remaps.co.uk
Trying to fit some new/used clocks to the car. Need the pins for the current and new/used clocks so used vag commander and heres the results
Old clocks info
ECU code 01400
Server Code 00443
i then click next and get
Pin 00001
New/Used clocks info
ECU code 01400
Server Code 00414
Pin 00001
Hoping this makes sense. then i follow this guide from Ross Tech
Immobilizer III Immobilizer Swapping (Instrument Cluster) - Ross-Tech Wiki
Now when i get to..........................
[17 - Instruments]
[Login - 11]
For the following procedure, use the PIN of the REPLACEMENT (NEW or USED) instrument cluster.
4-digit PIN
Enter zero followed by the 4-digit PIN directly in the Login field. For example, if your PIN is 1234, enter 01234.
[Do it!]
i get invalid code' ive tried all the codes thats in the first part of the post and none works. am i missing somthing
Old clocks info
ECU code 01400
Server Code 00443
Pin 00001
ECU code 01400
Server Code 00414
Pin 00001
[17 - Instruments]
[Login - 11]
4-digit PIN
[Do it!]
