Instrument Swap Troubles
Paul @ Unit 9 Remaps
north east U.K
Website
www.unit9remaps.co.uk
Trying to fit some new/used clocks to the car. Need the pins for the current and new/used clocks so used vag commander and heres the results
Old clocks info
ECU code 01400
Server Code 00443
i then click next and get
Pin 00001
New/Used clocks info
ECU code 01400
Server Code 00414
Pin 00001
Hoping this makes sense. then i follow this guide from Ross Tech
Immobilizer III Immobilizer Swapping (Instrument Cluster) - Ross-Tech Wiki
Now when i get to..........................
[17 - Instruments]
[Login - 11]
For the following procedure, use the PIN of the REPLACEMENT (NEW or USED) instrument cluster.
4-digit PIN
Enter zero followed by the 4-digit PIN directly in the Login field. For example, if your PIN is 1234, enter 01234.
[Do it!]
i get invalid code' ive tried all the codes thats in the first part of the post and none works. am i missing somthing :mad:
looks like its not pulling the skc code out
is it a snide vag commander ?
your vag commander sounds iffy, should have to just read eeprom and it will give pin after the hex screen populates.
for an a4 better off removing the clocks and reading the eeprom on the bench.
where abouts are you based?
I dont have much experience with the a4, but if your clone cable with read or allow you to save the eeprom dump your halfway there. I wouldnt suggest writing anything at all with it though, read only, if your lucky.
