EM TuningVolks Autos
    s3ollie's Avatar
    Jan 2007
    751
    Gen 3 steering rack s3
    Hi,
    I am fitting a gen 3 steering rack to my s3, upgrading from a gen 2.
    i have read on the Ross tech site and other places that I will need to get the new rack flashed with the appropriate characteristic curve and until then it will work with a linear curve.
    my question is will the car drive ok on a linear curve?
    i fitted a brand new gen 2 rack a few years ago and I never had a curve flashed to that so I'm guessing it could drive exactly the same as I'm used to anyway which will be fine as far as I'm concerned.
    hopefully someone will know,
    cheers
    8P S3
    s3ollie's Avatar
    Jan 2007
    751
    Just incase anyone does try this it works fine with no curve flashed (Kl. 000) It may be a tiny bit lighter when on the motorway.
    getting the curve downloaded on Thursday so it will be as it is intended.
    8P S3
    27,120
    Also between some gen versions, looms are required.
  1. Gen III Steering Rack Owners - Dull and Light?
    By NCRAW in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st August 2011, 19:34
  2. Possible Leaking Steering Rack A4 2.6 Quattro
    By RICHARDJC in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th March 2005, 11:40
  3. steering rack removal
    By zirconium in forum Classic Audi Forum
    Last Post: 8th September 2004, 09:09
  4. Steering rack problem
    By mramage in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th June 2004, 08:51
  5. Steering rack
    By GolfV5 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd March 2004, 23:27
