Volks AutosEM Tuning
Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By NHN
Thread: Very odd error code - anybody seen this before?
    Jul 2013
    East Lancs
    46
    Hi everyone,
    N8 very kindly scanned my car for error codes to try and get to the bottom of a problem that's mystifying all of the mechanics I know. The error codes were as follows:
    000000 - SAE - Reserved by Document ISO 15031-6
    P0000 - 006 - 2005 - Intermittent
    Freeze Frame:
    Fault Status: 01100001
    Fault Priority: 0
    Fault Frequency: 37
    Reset counter: 40
    Mileage: 0 km
    Time Indication: 0
    Freeze Frame:
    RPM: 1984 / min
    Torque: 144.0 Nm
    Text: Kein MEASVALUE verfuegbar
    Raw, Form. N / A: 000 000 000
    Auto HVAC Labels: 8E0-820-043.lbl
    Part No: 8E0 820 043 BL
    Component: A4 Klimaautomat 3233
    Coding: 00000
    Shop #: WSC 00000
    VCID: 6CD392611C222C78EC3
    1 Fault Found:
    00716 - Air recirculation Flap Positioning Motor (V113) 41-00 - Blocked or No Voltage
    Does anybody know what the first error code is or have you seen it before? I've tried google and hit the translate button on a German forum and a Russian forum but am none the wiser. Although the guy who posted it on the German forum appears to be getting told off for deleting his DPF and remapping his car, and the Russian owner was told his car might have had a bad map on it.
    My problems are excessive black smoke, lumpy idle, hesitation at about 2,000 rpm (like a slight flat spot), very easy to stall when cold but seems okay once it's warmed up. I am desperate to get this sorted.
    Thanks in anticipation.
    Jun 2011
    Great Melton Norfolk
    1,340
    Has N8 been in contact with Rosstech?
    Jul 2013
    East Lancs
    46
    I'm not sure he has yet. It would be just my luck to get an error code that isn't listed anywhere, I was so hoping to get a definitive answer to my car problem!
    26,762
    1st question, has dpf been deleted?
    N8 likes this.
    Jul 2013
    East Lancs
    46
    I honestly don't know, is there an easy way of finding out? I've only had the car for 6 weeks and although I know the service history I don't know if the previous owner has done anything else to it.
    26,762
    Would need visually checking I guess.
    Jul 2013
    East Lancs
    46
    Hi, I thought I'd post the resolution to this strange error code in case anybody else has the same issue. I had my car remapped on Saturday by Rick at Unicorn Motor Developments including DPF and EGR removal/delete. Rick has done a great job, it's now the car Audi should have made!
    Rick confirmed my suspicions - the car had already been tampered with. The DPF had been partially gutted and the ECU had been remapped - terribly as it turns out! So it appears this error code (000000 - SAE - Reserved by Document ISO 15031-6) is the result of somebody using a crap piece of software to try and delete the DPF.
    26,762
    Ah that's good to know it as the issue, well done Rick.
    Brodster's Avatar
    Shark Performance In Scotland
    Mar 2011
    Scottish Borders
    3,217
    Follow Brodster On Twitter Add Brodster on Facebook
    If your gonna do a DPF delete it has to be done correctly or this kind of gashness pops up. Im doing 1-2 DPF deletes a week and all are done properly with total removal of filter but cannister kept so OEM look. Happy customers all the way
    Angelwax/BBS/BCS/Bilstein/Cobra/CTS Turbo/H&R/K-Sport/KW/Loba/Milltek/Shark Performance/Oz Racing/VCDS/Wagner
    Jul 2013
    East Lancs
    46
    Totally agree Brodster, if you're going to have this done to your car get a true professional in to do it right first time!
    May 2009
    south yorkshire
    563
    no need to do a software dpf delete on these , its just a simple switch in the map .
  1. Fault Code.. Anybody had this before?
    By RyanGolfGTTDi in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th January 2010, 15:40
  2. Anybody seen this before?
    By psytech in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th February 2008, 21:04
  3. Anyone seen this before??
    By litfoo in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th December 2005, 19:16
  4. Ever seen this before?
    By necroeire in forum General Chat
    Last Post: 11th May 2005, 16:44
