Badger5Volks Autos
    Apr 2013
    Aberdeenshire
    595
    Activating follow me home lights on 2012 transporter
    Hi I scanned a relatives van tonight and had a look at enabling follow me home lights however on my car I had to change the codes,but on the van it would appear I only have to select the adaption and then click test is the correct or am I missing something ?
    27,129
    The bcm is probably different & uses a different setup, so yes its possible that is how that module is setup.
    Any pics of the module page?
    Apr 2013
    Aberdeenshire
    595
    Cheers I will get some tonight when I go into adaption it gives me the option do I just click test and do it ? As I don't adjust anything often I forget and fear messing up the motor maybe I should just man up !
    27,129
    Lets see what the module setup is 1st
    Apr 2013
    Aberdeenshire
    595
    Hope these help I coded it and got the error message I also coded and adapted a new polo for follow me home lights it accepted the codes but it didn't work not sure why ?
    i think the issue with the transporter as per images is software related .
  1. Coming Home & Leaving Home Lights Enabled
    By MarcQuinlivan in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5 Days Ago, 13:54
  2. Follow me home lights on a new A3 without autolights ~ solved
    By Helifella in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th December 2011, 13:06
  3. welcome home lighting
    By danny_s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th July 2008, 23:25
  4. Welcome Home Lights
    By Nilz in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th March 2008, 13:19
  5. Coming home light function
    By Tolmie18 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 3rd October 2007, 20:51
