Monster MotorsportVolks Autos
Thread: HVAC Error Code
    May 2013
    London
    52
    HVAC Error Code
    Any ideas how or why this was raised? Is is safe to clear and forget given that the fault frequency is only 1?
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 AD HW: 8P0 820 043 AD
    Component: KlimavollautomatH19 0360
    Revision: 071436 Serial number: 8P0820043AD
    Shop #: WSC 00000 000 00000
    VCID: 6EFD12CE79421368C27
    1 Fault Found:
    00796 - Fan for Interior Temp Sensor (V42)
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 155
    Mileage: 70095 km
    Time Indication: 0
    Date: 2013.07.04
    Time: 15:26:46
    Freeze Frame:
    Voltage: 13.60 V
    Temperature: 33.0°C
    27,111
    Did you remove any parts for double din work or anything at all?
    Just clear & see if returns.
    May 2013
    London
    52
    No, although I've only just bought the car and this error code happened ~3 weeks before so the previous owner may have swapped out RNSE for the current Concert2+. I want to install RNSE but will PM you about that.
    I'll clear it and see what happens, thanks!
    27,111
    Got your pm mate been away, will reply later if that's ok
  1. Error code 00519
    By Jules in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd August 2005, 12:18
  2. error code 00575, and sqealing noise
    By lowrider786 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th July 2005, 23:38
  3. S4 Error Codes?
    By SonicDeathmonkey in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th April 2005, 19:47
  4. Error codes!
    By S4ZippyZoo in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th November 2004, 12:43
  5. Flashing error code- "1n 1"
    By randallons in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th October 2004, 12:27
