Monster MotorsportVolks Autos
    Chris-gsxr's Avatar
    Oct 2012
    57
    Help with limp mode problem
    Cars in limp mode with the fault but the garage I'm using can't find the problem.
    Anyone have any suggestions?
    The code is 00665
    Turbo has been off for inspection. It was clean and in good order
    Dpf cleaned out. Still going in limp mode
    Sorry to re post. Not sure what section was best to post this in
    Hope someone can help
    Sent from my iPhone using Tapatalk 2
    Chris-gsxr's Avatar
    Oct 2012
    57
    Bump. Anyone?
    audi-a6's Avatar
    Aug 2011
    christchurch
    489
    take it you have checked all your pipes for leaks? Is your "dv" okay? N75 valve and n249 valve okay?
    Passat B5.5 tdi....... big plans to come
    Audi A3 8p motor way work horse
    Nissan Skyline r33 gts-t ..... my mid life crisis fun car
    Oct 2009
    Hull
    1,440
    Are they using a generic fault code reader as using something like vcds will give a description of the fault too
    Nothing comes up on ross tech wiki
    audi-a6's Avatar
    Aug 2011
    christchurch
    489
    this might be of some use
    16683/P0299/000665 - Boost Pressure Regulation: Control Range Not Reached
    Possible Symptoms
    Reduced Power Output
    Limp Mode
    Possible Causes
    Hoses/Pipes incorrect connected, disconnected or leaking
    Charger Pressure Control defective
    Turbocharger faulty
    Diverter Valve faulty
    Possible Solutions
    Check Hoses/Pipes to/between Components
    Check / Clean / Replace Charge Pressure Control
    Check Turbocharger
    Check Diverter Valve
    Special Notes
    When found in 2.0l TFSI: Check Boost Pressure Control Valve (N249), for cracked rubber diaphragm. A new/optimized Valve is available under Part # 06H-145-710-D (or newer). RoW vehicles see: TPI 2016331 for details.
    NAR vehicles see: TSB 01-07-70 or 2013392 for details.
    Chris-gsxr's Avatar
    Oct 2012
    57
    Cheers for that, ill pass the info on to see if anything has been overlooked
  1. Newbie with a limp mode problem .....
    By Slinequattro in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th October 2011, 19:01
  2. Help with a running problem on boost please
    By S£ in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th January 2011, 17:31
  3. Help with a few problems please?
    By jzr172 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 30th January 2010, 08:18
  4. Any help with my horn problem please?
    By sulaiman in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th November 2009, 22:41
  5. Crunching gears with limp mode!!
    By fasttdi in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th May 2009, 09:56
