Results 1 to 22 of 22
    Jan 2013
    Bolton, UK
    402
    Follow Aidy06 On Twitter Visit Aidy06's Instagram Channel
    Window mod question
    Hi, just purchased VCDS and trying to get to grips with it. Is there a mod I can do that would enable me to use my windows after I've turned the ignition off? As it stands now, when I stop the car and put the window up it will stop if I turn the ignition off which I do all the time. I want to be able to work the windows after the ignition is off, is this possible? Thanks
    05 DSG AUDI A3 2.0T FSI BLUEFIN'D
    FULLY REGISTERED VCDS USER
    T3nnant's Avatar
    Jan 2013
    Newcastle
    317
    surely cant be that big of a problem to sit for that extra 4 seconds?
    you can always press and hold the lock button on your key that will raise the windows and unlock will lower (but it does every window)
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,947
    as above use the fob
    Jan 2013
    Bolton, UK
    402
    Quote Originally Posted by T3nnant View Post
    It is, it's a massive problem. I don't like sitting in my car for longer than I have to ha. My two Golfs I had before my A3 did it so I'm sure it must be able to be activated. I don't use the fob to open/close all windows as when I had that on my Golf I came down one morning and all my windows where open haha
    bez101's Avatar
    Jul 2008
    7,947
    you cant mod it to keep power to the windows
    close them as your pulling up with 1 touch
    Jan 2013
    Bolton, UK
    402
    My Golf definitely used to it, I'd use the one touch and as they where going up I could turn ignition off and they'd finish closing.
    bez101's Avatar
    Jul 2008
    7,947
    golfs do keep power when igg is off
    the audi wont and no code to change it
    Jan 2013
    Bolton, UK
    402
    No problem, thanks for the info buddy
    Jan 2013
    Bolton, UK
    402
    Ok I've set the windows to open and close using the fob via VCDS, it's not working as it should though. If I hold the lock/unlock button the car opens but windows don't roll up/down, I have to press and hold the lock/unlock button AGAIN and then the windows will roll up/down. Is there something I'm missing somewhere? Thanks
    bez101's Avatar
    Jul 2008
    7,947
    Have u got selective locking 1 press drivers door 2nd press all doors ?
    Jan 2013
    Bolton, UK
    402
    No mate, I deactivated that. One click opens all as it is now
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,626
    I near certain I saw an option in VCDS to have Windows active for a few seconds after ignition off\key out? ..maybe opening the door cancels it?? but I'm sure I've seen something along those lines.
    2009 A3 SB 2.0T DSG S line
    Jan 2013
    Bolton, UK
    402
    Quote Originally Posted by Artimus View Post
    Yeah I've sussed that out, I can work windows after turning ignition off but comfort touch isn't available. I'm now stuck with the second querie I posted in this thread
    Jan 2013
    Bolton, UK
    402
    Still having trouble with this, surely I must be missing something somewhere?
    shariain's Avatar
    May 2004
    Glasgow
    1,170
    When I stop the engine and remove the key in my A3 and the S3 the windows still work without one touch until one of the doors are opened.
    S3 1.8t Ming blue with ivory leather & 18"tt alloys
    Jan 2013
    Bolton, UK
    402
    Quote Originally Posted by shariain View Post
    Yeah I've sorted that now mate, thanks. I'm now trying to get help with post 9
    shariain's Avatar
    May 2004
    Glasgow
    1,170
    That's what my 8p A3 does it. I press the button once the car locks/unlocks if I press the button again it then puts the windows up/down. I would think its better that way then you could avoid putting the windows up/down by accident like what has been posted on here a few times.
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,626
    Quote Originally Posted by Aidy06 View Post
    Didn't realise that was your second issue! as Sharain says, it's meant to be that way... prevents accidental opening.
    Aug 2013
    26
    Hi - this might not be the right thread.
    I have an 8P A3 and when I use my remote/key to lower or raise the window the windows don't drop level. One goes quicker than the other. Should it do this or have I got a fault?
    bez101's Avatar
    Jul 2008
    7,947
    you must have a bad motor
    Aug 2013
    26
    It's not a massive issue but I notice it. Just worry that when the other side is up I am still running the motor for Nother second while the other catches up!!
    Sep 2013
    Heysham and Catterick
    24
    Check your window seal it might be slowing it down burning your motor out
  1. Mk1 180bhp Roadster Remap / Mods Question
    By Stevie C in forum TT/TT-S/TT-RS Forum
    Last Post: 22nd February 2009, 19:55
  2. Dv and other mods Question
    By mattypgolf in forum Diesel forum
    Last Post: 22nd December 2008, 15:27
  3. couple of mod questions
    By AUDI TURBO in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd June 2008, 16:07
  4. window motor question.
    By vw754 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 23rd May 2008, 16:11
  5. ARB's and suspension mod questions!
    By stevieyid in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st May 2008, 21:44
