AH FabricationsChris Nott
Results 1 to 17 of 17
Like Tree1Likes
  • 1 Post By Audi Toby!
Thread: NORWICH, NORFOLK FULL VCDS.
    Audi Toby!'s Avatar
    B8 A4 S-Line
    Jun 2013
    Norwich, Norfolk, UK
    227
    If any body needs ANYTHING doing ill be able to help you out.
    2009 (B8/8K) A4 S-Line - 2.0TDI (CAGA) 143PS.
    Monza Silver, Special Line, Full Milano Leather, Sport Suspension (1BE), AMI + Bluetooth/Voice Prep, Heated Seats, Bang & Olufsen (Upgraded/Improved), Audi Titanium Grey Wheel Refurb, Team HEKO Wind Deflectors, VCDS'ed, Ambiance Lighting Retrofit, Cruise Control Retrofit, (ADS) Audi Drive Select Retrofit.
    Find me on the 'official' VCDS map >>
    http://goo.gl/5NrQwS<<
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,500
    Quote Originally Posted by A4 Toby View Post
    Toby, if you go to the vcds section and click on the link to be added to the vcds map, this will allow others to know where you are. x
    Audi Toby!'s Avatar
    B8 A4 S-Line
    Jun 2013
    227
    Thanks Sandra, I tried the link but it said they arnt taking any applications at the moment. I'm in central Norwich (no one else on the map within 20 miles)
    Toby
    Sandra likes this.
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,500
    Toby
    You have pm x
    dave H's Avatar
    Mar 2014
    13
    hi do you still do v com if so where abouts are you thanks
    Using Tapatalk
    Audi Toby!'s Avatar
    B8 A4 S-Line
    Jun 2013
    227
    I'm in Norwich.
    dave H's Avatar
    Mar 2014
    13
    where abouts chap could realy do with some tech help
    Using Tapatalk
    Audi Toby!'s Avatar
    B8 A4 S-Line
    Jun 2013
    227
    Central, what's the problem? What vehicle is it on?
    dave H's Avatar
    Mar 2014
    13
    a4 b6 pd 115 ecm light no power the list goes on
    Using Tapatalk
    dave H's Avatar
    Mar 2014
    13
    are you garrage based ccan i book in nb hate touch phones
    Using Tapatalk
    Audi Toby!'s Avatar
    B8 A4 S-Line
    Jun 2013
    227
    I'm not garage based, just own the the software for personal use and to help people out. It could be so many things wrong with it, only way is to have a scan. I could arrange something for when I finish work.
    dave H's Avatar
    Mar 2014
    13
    sounds good bit random but a massive blast up and down the 47 and the ecm light has gone out i think when i had it all stripped down some gunk got stuck some where i did the old mr muccle trick
    Using Tapatalk
    Audi Toby!'s Avatar
    B8 A4 S-Line
    Jun 2013
    227
    That's probably it mate, as a rule I always make sure I remove all the sensors and clean them with electronics spray after I've done a complete clean of the air system. Biggest problem got engines are the sensors!
    dave H's Avatar
    Mar 2014
    13
    should have seen it bad real bad mostly down to euro c part givin me the wrong oil 5-30 not 40 too thin i now run quantum plat
    Using Tapatalk
    dave H's Avatar
    Mar 2014
    13
    since that mistake ive been like a book worm researching all parts and fluids
    Using Tapatalk
    Audi Toby!'s Avatar
    B8 A4 S-Line
    Jun 2013
    227
    Any questions about your car, call Norwich Audi and ask for parts they will always tell you even if you don't buy the fluids/parts from them. Just to be sure!
    Audi Toby!'s Avatar
    B8 A4 S-Line
    Jun 2013
    227
    Euro and GSF always have lots of variants and the systems aren't as accurate as main dealers. I've had too many headaches trying to find the right parts with them lol
  1. 1999 A6 ABS purge, VCDS full or shareware needed?
    By @udi A3 in forum VCDS (formerly VAG-COM) forum
    Last Post: 24th August 2012, 12:46
  2. Sidelights With Full Brightness DRL's VCDS Mod (3 dr facelift A3/S3's only)
    By Paullie in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th March 2012, 17:12
  3. Help with Full VCDS....
    By Mackers in forum VCDS (formerly VAG-COM) forum
    Last Post: 9th January 2012, 00:37
  4. Anyone with Full vcds in manchester area??
    By k9audi in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th October 2011, 10:40
  5. VCDS Full scan output...Please help has thrown up many faults
    By Mk3-ralf in forum VCDS (formerly VAG-COM) forum
    Last Post: 14th July 2011, 10:26
