KowalskiAWEsome GTI
    Nov 2005
    UK
    12
    Post Thanks / Like
    Second opinion on error codes needed
    Hi,
    I have a 2002 1.8T A3, 38000 miles.
    A local independent did a diagnostic recently and reported these error codes.
    17545
    17705
    His conclusion from this and after taking it for an "extended test drive" (although i found a shopping list on my passengar seat for a mcdonalds order when i picked the car up - hence ive totally lost faith in them) Is that its an early warning that the cylinder head gasket is on the way out and that I should run the car until any running problems occur, then bring it back to him with £400 - £600 in my back pocket for him to sort out.
    (by the way this is the 3rd time has has done thie diagnostic for me - same codes three times - took him till this go to diagnose head gasket. - thats 75 quid in diagnotics - and the check engine light came on again the next day and is still on)
    Can anyone advise if the above diagnosis sounds right?
    Oh and anyone want a big mac whilst im going? [img]/ubbthreads/images/graemlins/mad.gif[/img]
    Jul 2005
    2,487
    Post Thanks / Like
    Re: Second opinion on error codes needed
    sounds like balls to me (alledgedly, blah blah blah ofc)...
    17705 - Pressure Drop between Turbo and Throttle
    17545 - Fuel Trim : Bank 1 ( add ) System too rich
    try lambda first, clear, then re-scan.
    Jul 2005
    2,487
    Post Thanks / Like
    bit-o-further googling:
    VAG DTC 17545:
    - Check fuel pressure regulator and holding pressure.
    - Check quantity of fuel injected and check for leaks.
    - Check Evaporative Emission (EVAP) canister purge regulator valve -N80-
    (still personally reckon lambda)
    17705 - check DV and MAF
    Out of interest, what local independant are you using?
    Nov 2005
    UK
    12
    Post Thanks / Like
    sorry mate - should have said in forst post - im new to all this so no idea what "try lambda first, clear, then re-scan. " means
    sounds like i need to get a cable and vag-com freeware asap??
    wouldnt feel too comfortable naming names just yet mate - im new here and not sure who reads these pages.
    lets just say if theyve read the above they'll recognise the car. i am in the north west of england, so any recommendations locally would be welcome!
    EDIT : just been googling on this.
    Found this thread:
    http://www.briskoda.co.uk/forums/sho...d.php?p=239049
    Its a bit old, and it relates to a Skoda, but they are the exact same two codes and replace of a "dump valve" sorted the problem.
    Is this a clue? Is there a technical bulletin 56 out there with the answer to my problems?
    peteA3tdi's Avatar
    Mar 2004
    the rose and crown
    406
    Post Thanks / Like
    sounds like an air leak to me and a new 'DV' may well fix it they are under £20 so worth a try do a search on DV's ect to see how to fit one
