Badger5Chris Nott
Results 1 to 7 of 7
    Apr 2013
    26
    Help with code 013230 - Control Module for Climatronic
    Hi all,
    After searching for the code below, I can see it is fairly common as it often shows in posted scans.
    01320 - Control Module for Climatronic (J255)
    004 - No Signal/Communication - Intermittent
    But I can't find any information as to the cause of it.
    Can anyone help, and explain what it is and how to get rid of it?
    Many thanks guy's
    27,114
    Have you cleared it & then rescanned?
    Apr 2013
    26
    Yep, I cleared it and it came back as soon as I switched on the ignition, didn't even have to run car...
    Interesting though, as the original fault that came up yesterday (3rd July) when I scanned was..
    1 Fault Found:
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 3
    Reset counter: 243
    Mileage: 144480 km
    Time Indication: 0
    Date: 2013.06.14 <<===== Note Date and time
    Time: 15:41:00
    Freeze Frame:
    OFF
    Voltage: 12.10 V
    OFF
    ON
    OFF
    OFF
    OFF
    Guess what I was doing on Friday 14th June at 15:41, yes you got it I was fiddling..
    What I was actually doing was the Ash Tray Delete mod which involved removing the Climate unit to allow the ash tray replacement cubby hole thing to be fitted !!
    I have checked the dates and time, and that is exactly when I did it ??
    I didn't remove the battery, and I certainly didn't turn on the ignition with the unit removed, so unsure why the fault came up.
    More to the point, why does it now reappear if I remove the fault code ?
    The Air Con works fine, Ambient of 23 degrees today and I just measured 11 degrees at the vents, rising to 24 degrees when It switched it to Econ, so that is all good..
    I am guessing that it needs to all come out again to check the plugs are home.
    Anyone got any other idea's ?
    Thanks again guy's..
    27,114
    Check connectors are all plugged in.
    Also login in 08, go to basic settings, select 001, then go & let it do its adp calibration, when done, rescan & see if still there.
    Apr 2013
    26
    Ok, thanks for that..
    What exactly does "login in 08, go to basic settings, select 001, then go & let it do its adp calibration" actually do ?
    I am sure it is safe and won't screw anything up, just interested in what it does ?
    Thanks again.
    27,114
    Calibrates all the sensors & motors/flaps to test for any issues & usually helps clear errors.
    Apr 2013
    26
    Had a look at this earlier..
    I take it you mean login to Module 08 HVAC and then go to Basic ?
    I tried that, and selected 001 and GO, but it didn't seem to do much, I was expecting to see something happening?
    I think I saw ADP in the first column of group 001, so maybe it was doing something ?
    I also noticed that and it said Basic Off at the top, but there was a button towards the top right hand side that I think said on/off on it.. Do I need to select that ?
    If anyone has full detailed instructions then that would be handy ?
    Thanks again for your help.
  1. Replies: 1
    Last Post: 3rd June 2013, 14:35
  2. A4 B6/7 Steering Wheel Control Module for Cruise
    By PhilW in forum For Sale/Wanted - Audi Parts
    Last Post: 28th September 2011, 12:13
  3. Control Module for Injection Pump (J399) - Audi A4, 2.5Tdi, Avant 2002, B6
    By seanr in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th July 2011, 20:24
  4. Control module for injection pump
    By colinr in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 31st July 2007, 21:32
  5. new user help with elec window control
    By imported_kenloen in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd April 2005, 08:12
