Volks AutosBadger5
Results 1 to 23 of 23
Like Tree1Likes
  • 1 Post By NHN
Thread: Brand new RNS-E won't take codes
    May 2013
    13
    Hello,
    I purchased a brand new in the box 2010 RNS-E and installed it into my 2012 A3. The person doing to vagcom say it will not take any of the coding. The navigation never asked me for a security code I am assuming because it was unused and mated with my car. What I don't know is why it will not take the code, and I am thinking it is because of the security code even though it did not ask for it? Any help would be appreciated. I am sitting at the shop now and have been here for 5
    hours!
    May 2013
    13
    Also I am using a 2010 genuine Lamborghini Gallado disk. Could this be the problem? The disk seems to work for the navigation and updating the software.
    27,114
    Whose trying to code it for you?
    May 2013
    13
    A guy from USP motorsports in Coral Springs Florida. He seems to know what he is doing so, not sure what to think.
    27,114
    Need to log of the car 1st & also what coding is he trying to enter?
    BTW we can supply rns-e units to the US market, also supply them with SDS
    May 2013
    13
    NHN not sure what you mean about logging the car as I have not done any programming before. I am only trying to get the AUX in function to work. Everything else with the navigation seems to work fine. The Bluetooth works, navigation works, I can see names and numbers of calls on both the navigation screen as well as the cluster. The only thing that does not work is the AUX in. When I press media it does not show AUX as an option. I have moved the wires to the new connector but it seems it is not enabled on the RNS-e.
    The software says it is at SW version 260.
    27,114
    You will need to code the rns to tell the unit it has auxin ability, so what's the rns code presently?
    May 2013
    13
    Yes NHN that is my problem. The guy could not get the RNS-E to enable the AUX in. The A3 had the AUX under the arm rest from the factory so I move the wires to the new harness. So I am not sure what my coding is as I am paying this guy to program it as I do not have access to a vagcom computer. The car also has sat radio which works fine with the RNS-E.
    27,114
    If the guy has vcds, why didn't he just look at the wiki or ring ross-tech direct for support unless he has a counterfeit vcds cable.
    It pops up with a helper to explain what coding it needs, so I fail to see why he cant do it.
    Audi Radio/Navigation System (RNS-E) - Ross-Tech Wiki
    As I've asked now 3 times, what's the coding of the unit now, in other words, maybe try ringing him & asking what it is, if he's logged the fault & also I would look elsewhere tbh if they cant code it properly, its not the hardest of jobs to do tbh.
    May 2013
    13
    I am calling now as I type to see if he can give me the coding as it was. I did not leave the car there so I am not sure if it will be logged or whatever. I even brought a print out of that wiki page with me to show him the coding. I agree to me it sounds easy so there must be something going on.
    Ok just got a call. I talked to the service manager who said I need to bring it back in and something about they think they need to fix another problem before they can code it. I have no idea what that means just telling you what he said.
    Also this was the only guy I could find that would do this for me I called everyone in a 75 mile range and they were the only ones. No dealers would even listen to what I need done.
    I wish I could tell you more.
    May 2013
    13
    Also I think he has some type of support through ross tech or something like that because he was going back and forth with them on the phone all day.
    Brodster's Avatar
    Shark Performance In Scotland
    Mar 2011
    Scottish Borders
    3,403
    Follow Brodster On Twitter Add Brodster on Facebook
    This seems a little strange in my eyes as this takes minutes to recode and cant see how the module would lock him out unless as NHN says its a dodgy cable.
    Angelwax/BBS/BCS/Bilstein/Cobra/CTS Turbo/DTUK/H&R/K-Sport/KW/Loba/Milltek/Shark Performance/Oz Racing/TPI/VCDS/V-Maxx/Vossen/Wagner
    May 2013
    13
    I am pretty sure he expected it to take a few minutes also. He told me to come by and it should be done in less then a half hour. I mean there are write ups on the wall from different tuning magazines about the guy. He seems to be known in the VW/Audi community. His name is Chris Green. I think there is a problem as you all said it should be simple and only take a few minutes.
    May 2013
    13
    I am dropping it off in the morning and he wants me to leave it there for the day. I will let you guys know what happens.
    Brodster's Avatar
    Mar 2011
    Scottish Borders
    3,403
    Get him to write down or tell you exactly what the problem was or what he did exactly as it never takes that long to do.
    27,114
    Better still, buy vcds from Ross-tech direct, say NHN sent you, then load up onto your laptop, create a free account @ logmein.com & pay me to remote access it to code for you
    May 2013
    13
    NHN that does sound like a good idea now that this is such a pain. The shop is close to an hour away, and dropping it off there all day does not make it easy to get to everyone to work on time. I will ask him again what is happening or the reason it will not work.
    27,114
    Ross-tech will send it for next day or so afaik, imho just buy a cable as they should of easily resolved this by now, taking the car there for all day & then not working still is pointless & its an hour away.
    May 2013
    13
    NHN, here is what he sent me. Again he said he tries to change the code and it won't accept it. Not sure what that means but that is what he said. I also have more stuff from the scan, but did not know how much I could put in this reply.
    Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
    Part No SW: 8P0 035 193 D HW: 8P0 035 193 D
    Component: RNS-E PU US H04 0210
    Revision: 0000006S Serial number: AUZBZ7K7000395
    Coding: 0205600
    Shop #: WSC 12345 444 54321
    VCID: 3169C84EA82D78909F5
    5 Faults Found:
    00862 - Antenna for GPS Navigation (R50/R52)
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 3
    Mileage: 16658 km
    Time Indication: 0
    Date: 2013.06.30
    Time: 22:55:15
    Freeze Frame:
    Mileage: 16650 km
    Count: 3006
    Clock: 23:11
    00856 - Radio Antenna
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 3
    Mileage: 16658 km
    Time Indication: 0
    Date: 2013.06.30
    Time: 22:55:16
    Freeze Frame:
    Mileage: 16650 km
    Count: 3006
    Clock: 22:56
    00858 - Connection; Radio ZF Output to Antenna Amplifier
    007 - Short to Ground
    Freeze Frame:
    Fault Status: 01100111
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 218
    Mileage: 16661 km
    Time Indication: 0
    Date: 2013.06.30
    Time: 23:37:55
    Freeze Frame:
    Mileage: 16660 km
    Count: 3006
    Clock: 23:37
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 3
    Mileage: 16658 km
    Time Indication: 0
    Date: 2013.06.30
    Time: 22:55:16
    Freeze Frame:
    Mileage: 16650 km
    Count: 3006
    Clock: 22:56
    01042 - Control Module; Not Coded
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 0
    May 2013
    13
    I appreciate any insight you have on this situation. Thanks in advance.
    VCDS Version: Release 11.11.6
    Data version: 20121223
    Monday,01,July,2013,14:27:17:01058
    Chassis Type: 7N0
    Scan: 01 02 03 08 09 0F 15 16 17 19 25 37 42 44 46 47 4C 52 55 56
    62 72 77
    VIN: WAUKEAFM9CA132423 Mileage: 16690km/10370miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    0F-Digital Radio -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010 25-Immobilizer -- Status:
    OK 0000 37-Navigation -- Status: Not registered 0011 42-Door Elect,
    Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000
    4C-Tire Pressure II -- Status: OK 0000 52-Door Elect, Pass. -- Status:
    OK 0000 55-Xenon Range -- Status: OK 0000 56-Radio -- Status:
    Malfunction 0010 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear
    Right -- Status: OK 0000 77-Telephone -- Status: OK 0000
    Address 01: Engine (CBF) Labels: 06J-907-115-CBF.clb
    Part No SW: 8P0 907 115 BC HW: 8P0 907 115 AL
    Component: 2.0l R4/4V TFSI 0010
    Revision: E3H26--- Serial number: AUX7Z0L1FN8089
    Coding: 010301081C070160
    Shop #: WSC 06314 000 00000
    VCID: 74E7015A17BF0DB8343
    No fault code found.
    Readiness: 0000 0000
    Address 02: Auto Trans Labels: 02E-300-0xx.lbl
    Part No SW: 02E 300 057 R HW: 02E 927 770 AL
    Component: GSG DSG AG6 512 3115
    Revision: 05551213 Serial number: 00001202172249
    Coding: 0000020
    VCID: 285F252A9BF7395848B
    Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
    Component: ESP MK60EC1 H31 0121
    Revision: 00H31001
    Coding: 1150600F492500FC880F06E6921C0041BF0C00
    VCID: 7BF52A66FAE142C0759
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 BM HW: 8P0 820 043 BM
    Component: KlimavollautomatH09 0180
    Revision: 000362 Serial number: 8P0820043BM
    Shop #: WSC 00000 000 00000
    VCID: 78FF356A0BD769D818B
    Address 09: Cent. Elect. (J519) Labels: 8P0-907-063.clb
    Part No SW: 8P0 907 063 Q HW: 8P0 907 063 Q
    Component: BCM PQ35 M 110 0667
    Revision: AJ110667
    Coding: 6E000A0FA01336E4287041E000100D4D401E62AA104DD92AE4 0008840040
    VCID: 428B9782DD8BF30876F
    Subsystem 1 - Part No SW: 8P1 955 119 F HW: 8P1 955 119 F Labels:
    1KX-955-119.CLB
    Component: Wischer AU350 H11 0050
    Coding: 00DD13
    Subsystem 2 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HO H05 1501
    Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
    Part No SW: 8E0 035 593 P HW: 8E0 035 593 P
    Component: SDAR SIRIUS H07 0160
    Revision: 00000000 Serial number: AUZ4Z7M0611455
    Coding: 0000100
    VCID: 3663FB5241435FA8CA7
    Address 15: Airbags (J234) Labels: 8P0-959-655-10.clb
    Part No SW: 8P0 959 655 Q HW: 8P0 959 655 Q
    Component: Airbag AU1042 H10 0250
    Revision: -------- Serial number: 003FC001NVZY
    Coding: 303142393041303030374A55304C38503053
    ASAM Dataset: EV_Airba10AURB4 001001
    ROD: EV_Airba10AURB4.rod
    VCID: 50AFADCA0BE71198F0B
    Seat occupied recognition:
    Subsystem 1 - Part No SW: 8P0 959 339 E HW: 8P0 959 339 E
    Component: BF-Gewichtss. H04 0040
    Serial number: 5850000R11B08R1QMK
    Coding: 000000
    Crash sensor for side airbag; driver side:
    Serial number: 3572DRB40000E53091DV
    Crash sensor for side airbag; passenger side:
    Serial number: 3582DRB40000E528C982
    Crash sensor for side airbag; rear driver side:
    Serial number: 35128RB40000696230EF
    Crash sensor for side airbag; rear passenger side:
    Serial number: 35228RB40000695A82AQ
    Crash sensor for front airbag; driver side:
    Serial number: 35547RB40000692BD27U
    Crash sensor for front airbag; passenger side:
    Serial number: 35647RB40000692BD24S
    Address 16: Steering wheel Labels: 8P0-953-549.lbl
    Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
    Component: J0527 H38 0070
    Coding: 0014142
    VCID: 46838B9231A3CF285A7
    Part No: XXXXXXXXXXX
    Component: E0221 H02 0100
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
    Part No SW: 8P0 920 983 C HW: 8P0 920 983 C
    Component: KOMBIINSTR. VDO H03 0150
    Revision: D0H03002 Serial number: 2241L002002929
    Coding: 0272288
    Shop #: WSC 05123 444 12497
    VCID: 3A7BEF62755BBBC82EF
    Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
    Part No SW: 7N0 907 530 M HW: 1K0 907 951
    Component: J533 Gateway H42 1623
    Revision: H42 Serial number: 210212F6000305
    Coding: 352102
    VCID: 3A7BEF62B55BBBC82EF
    1 Fault Found:
    01044 - Control Module Incorrectly Coded
    000 - -
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 108
    Mileage: 13434 km
    Time Indication: 0
    Date: 2013.05.11
    Time: 12:58:02
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Revision: D0H03002 Serial number: AUX7Z0L1FN8089
    Coding: 0205600
    5 Faults Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 3
    Mileage: 16658 km
    Time Indication: 0
    Date: 2013.06.30
    Time: 22:55:15
    Freeze Frame:
    Mileage: 16650 km
    Count: 3006
    Clock: 23:11
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 3
    Mileage: 16658 km
    Time Indication: 0
    Date: 2013.06.30
    Time: 22:55:16
    Freeze Frame:
    Mileage: 16650 km
    Count: 3006
    Clock: 22:56
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 218
    Mileage: 16661 km
    Time Indication: 0
    Date: 2013.06.30
    Time: 23:37:55
    Freeze Frame:
    Mileage: 16660 km
    Count: 3006
    Clock: 23:37
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 3
    Mileage: 16658 km
    Time Indication: 0
    Date: 2013.06.30
    Time: 22:55:16
    Freeze Frame:
    Mileage: 16650 km
    Count: 3006
    Clock: 22:56
    000 - -
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 0
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
    Part No SW: 8P0 959 801 Q HW: 8P0 959 801 Q
    Component: Tuer-SG H04 0101
    Coding: 0001181
    VCID: 499980AE20BD2050B75
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K0 909 144 P
    Component: EPS_ZFLS Kl. 233 3305
    Revision: 00H22000
    Shop #: WSC 02069 000 90108
    VCID: 377DF6564649A6A0D11
    Address 47: Sound System Labels: 8Px-035-382.lbl
    Part No SW: 8P4 035 382 E HW: 8P4 035 382 E
    Component: AB2 SUBWOOFERBOXH07 0180
    Revision: 00006 Serial number: 92158128935283
    Address 4C: Tire Pressure II
    Cannot be reached
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
    Part No SW: 8P0 959 802 Q HW: 8P0 959 802 Q
    Coding: 0001181
    VCID: 4A9BBFA225BB2B48BEF
    Address 55: Xenon Range (J431) Labels: None
    Part No SW: 8X0 907 357 C HW: 8X0 907 357 B
    Component: ****LWR12**** H02 0012
    Serial number: 120131-0001-033
    Coding: 1163951010020000
    ASAM Dataset: EV_HeadlRegulBasic 005001
    ROD: EV_HeadlRegulBasic_AU35.rod
    VCID: 428B9782D58BF30876F
    Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
    Coding: 0205600
    5 Faults Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 3
    Mileage: 16658 km
    Time Indication: 0
    Date: 2013.06.30
    Time: 22:55:15
    Freeze Frame:
    Mileage: 16650 km
    Count: 3006
    Clock: 23:11
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 3
    Mileage: 16658 km
    Time Indication: 0
    Date: 2013.06.30
    Time: 22:55:16
    Freeze Frame:
    Mileage: 16650 km
    Count: 3006
    Clock: 22:56
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 218
    Mileage: 16661 km
    Time Indication: 0
    Date: 2013.06.30
    Time: 23:37:55
    Freeze Frame:
    Mileage: 16660 km
    Count: 3006
    Clock: 23:37
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 3
    Mileage: 16658 km
    Time Indication: 0
    Date: 2013.06.30
    Time: 22:55:16
    Freeze Frame:
    Mileage: 16650 km
    Count: 3006
    Clock: 22:56
    000 - -
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 0
    Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
    Part No SW: 8P4 959 801 F HW: 8P4 959 801 F
    Component: Tuer-SG H04 0050
    Coding: 0001176
    Shop #: WSC 06314 000 1012544
    VCID: 428B97821D8BF30876F
    Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
    Part No SW: 8P4 959 802 F HW: 8P4 959 802 F
    Coding: 0001176
    VCID: 438592860291FA007D9
    Address 77: Telephone Labels: 8P0-862-335.lbl
    Part No SW: 8P1 862 336 A HW: 8P1 862 336
    Component: FSE_256x BT H44 0660
    Revision: 00000000 Serial number: 00000005162902
    Coding: 0001277
    End
    _______________________
    27,114
    Quote Originally Posted by Downtownfish View Post
    Coding: 0000100
    Coding: 0014142
    Coding: 352102
    1 Fault Found:
    000 - -
    Freeze Frame:
    Fault Priority: 1
    Mileage: 13434 km
    Time Indication: 0
    Date: 2013.05.11
    Time: 12:58:02
    Coding: 0205600
    5 Faults Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 3
    Mileage: 16658 km
    Time Indication: 0
    Date: 2013.06.30
    Time: 22:55:15
    Freeze Frame:
    Mileage: 16650 km
    Count: 3006
    Clock: 23:11
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 3
    Mileage: 16658 km
    Time Indication: 0
    Date: 2013.06.30
    Time: 22:55:16
    Freeze Frame:
    Mileage: 16650 km
    Count: 3006
    Clock: 22:56
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 218
    Mileage: 16661 km
    Time Indication: 0
    Date: 2013.06.30
    Time: 23:37:55
    Freeze Frame:
    Mileage: 16660 km
    Count: 3006
    Clock: 23:37
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 3
    Mileage: 16658 km
    Time Indication: 0
    Date: 2013.06.30
    Time: 22:55:16
    Freeze Frame:
    Mileage: 16650 km
    Count: 3006
    Clock: 22:56
    000 - -
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 0
    Well it doesn't have Bose, has BT, MFSW, Sat radio & antenna system is different which I would say you havnt sorted either.
    I would try coding 37 with 0205775, it may differ a little because of the sat radio etc, but try this for now.
    Also you need to go into 19 Can Gateway, click on installation list & tick the box for 37 Nav & Save, as its showing not registered, so showing incorrect coding for that module.
    I still standby you getting your own VCDS & getting me to login remotely, its so much more convenient at end of the day & we could troubleshoot this allot easier.
    May 2013
    13
    I understand the coding is still wrong. The problem is the RNS-E will not accept new coding to change it to what I need. The guy trouble shot this problem with ross tech for a few days. NHN I would be willing to buy VCDS and have you do it, but I am not sure that will work. The guy knows what coding to use, but again the RNS-E will not take the new coding. So I am afraid to go out and buy this to have you tell me the same thing.
    27,114
    I suggest you get them to reload the firmware then, best I can offer is what I've given so far, without seeing what the unit is doing, I cant help much more, for all we know they're inputting incorrectly, its like Chinese whispers atm fella, no offence.
    Brodster likes this.
  1. Won a Brand New TT for this weekend!!!
    By Maskwelli in forum General Automotive Chat
    Last Post: 21st May 2013, 19:57
  2. Brand New 1 piece oem valeo projectors 100
    By imported_Yaseen in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th November 2004, 09:09
  3. weh hey.... picked up my brand new s3 today.
    By andyb in forum The Welcome Section
    Last Post: 29th October 2003, 13:39
  4. Brand new evo anyone lol
    By DaveCav in forum General Chat
    Last Post: 30th September 2003, 09:33
