Chris NottEM Tuning
    Aug 2008
    60
    2.0TDI quattro (170) A3- Diagnostic error codes - EGR sensor bank P2080, P0544 - Help
    So my A3 2.0L TDI quattro (170 PS) has the engine management light on constantly and the glowplug light is occasionally flashing. I took it for diagnostics at Kwik-fit (the only people who could see me at the time) and it gave two codes.
    P2080
    P0544
    According to what I was told therse relate to sensor banks on the EGR valve.
    Also some reading onthe net shows this to be a problem with some VW Jettas.
    A few questions if you please...
    Anyone else had this problem?
    Can I just have the sensors replaced or does the whole EGR valve need replacing?
    What causes these failures?
    any idea on how much it should cost? (Kwik-Fit are quoting £254.14, D-tech in Sudbury wouldn't quote over the phone and I am too scared to get a quote from Audi
    Driving my new-generation A3 2.0L TDI Sport Quattro... *vroom, vroom*
    Stoopid handbrakes
    May 2012
    RETFORD, NOTTS
    1,753
    I think you have EGT issues not EGR.
    Could also be DPF related if u have a DPF, would recomend scanning with VCDS and checking soot levels in the DPF at the same time.
    You will get a lot more info about the fault with VCDS than quick fit have told you.
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    Aug 2008
    60
    Quote Originally Posted by @udi A3 View Post
    Know anyone in Bury St Edmunds who will do that?
    Yeah, I know but I needed to have it checked ASAP as I didn't know what the problem was.
    Yep, EGT may be where the problem is alright. See this thread. This is why I need more info on EGT vs EGR. The guy at Kwik-Fit said that the EGR would need replacing, hence my question earlier.
    Incidentally, the guy at Kwik-fit didn't fill me with confidence as they need to call in a 'specialist' to do this work but I don't want them ordering a part I don't need only for that not to fix the problem
    Anyone else got any thoughts?
    Stoopid handbrakes
    May 2012
    RETFORD, NOTTS
    1,753
    gen.heinz looks the most local and active user to yourself,
    VCDS (formerly VAG-COM) forum
    Ive pm'd you my number though incase you want this scan doing this evening and want to cover my fuel, wont cost me much as i stick to the speed limits and middle lane hog lol
  1. Just bought an Audi A3 07 2.0TDI S-Line Sportback Quattro (170)
    By Napbree in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th February 2013, 21:03
  2. Audi A3 2.0TDI - Error codes...
    By x1nick in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd May 2012, 22:26
  3. 2.0TDI 170 (BRD) - injector cleaners, EGR cleaning, MAF cleaning.
    By brixo in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 23rd June 2011, 16:10
  4. A6 C6 3.0tdi quattro EGR valve clean
    By singhl in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 4th August 2009, 12:12
  5. Replies: 21
    Last Post: 20th April 2008, 17:02
