Results 1 to 7 of 7
Like Tree2Likes
  • 1 Post By @udi A3
  • 1 Post By A4Ade
Thread: do i need to and can i recode ABS module with VCDS lite?
    Jun 2012
    Essex
    59
    Hi,
    i used VCDS lite to confirm my ABS module was faulty and have managed to find another with exactly the same part number. The car is a 1998 Audi A4 Avant i.8 petrol Auto
    I`ve been told it should work providing the part number is the same, i`ve also been told i will need to recode the new one with VCDS lite and i`ve also been told i will need the full version to extract the code from the old one to put on the new one. I`ve had a look at the Ross - Tech website to look at functionality but to be totally honest i`m not sure what i already have will do the job or not.
    can anyone help?
    May 2012
    RETFORD, NOTTS
    1,748
    Youd need to look into the correct coding for your car.
    Shareware Limitation(s):
    • Coding charts and suggestions are not available in Shareware.
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    Jun 2012
    Essex
    59
    Quote Originally Posted by @udi A3 View Post
    thanks for the reply, any idea where i can find the correct coding for my car?
    once i have that can i recode with VCDS Lite or do i need to register it?
    May 2012
    RETFORD, NOTTS
    1,748
    NHN or Brucethebear are probably best to ask, i just have the full version, worth its weight in gold imo !
    NHN likes this.
    Jun 2012
    Essex
    59
    when funds allow the full version is on the cards, thanks for your help
    A4Ade's Avatar
    Back from the dead
    Jul 2008
    Lancaster
    80
    I put together a tool for working out the coding of various modules after a DIS/Cruise retrofit. That includes recoding the ABS module, and shows how you can work out your codes if you don't know them - it was specifically for a B6 A4 though, so not sure if it will cover your model, but might be worth a look? Link is in my sig...
    EDIT - OK, I'm guessing you have a B5, so will need to look at this to work out your codes:
    http://wiki.ross-tech.com/wiki/index...BS/EDS/ASR/ESP)
    deejames likes this.
    Jun 2012
    Essex
    59
    thanks very much, i`ll check it out
  1. Replies: 4
    Last Post: 15th May 2013, 16:00
  2. Audi A6 C5 and CAN Bus
    By toto in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 18th December 2006, 13:18
  3. HELP Retrofitting cruise control, need VAG-com can in south west UK
    By Dannyboyski in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th February 2006, 21:03
  4. Hesitation and Can I believe this Rolling Road Figure?
    By AL_B in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th December 2005, 09:06
  5. Needed, bits and pieces......
    By thewizkid in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st December 2004, 13:15
