Sky InsuranceAH Fabrications
Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By A4Ade
Thread: Purchased VAG Com..
    May 2010
    Glasgow
    31
    Purchased VAG Com..
    Purchased the cable from NHN on this site (great service, well recommended).
    Now... what funky things can I do with this bad boy other than scan for codes? Can someone point me towards any sites or even in the right direction?
    I've just bought an A5 too so looking forward to have a play around with that!
    A4Ade's Avatar
    Back from the dead
    Jul 2008
    Lancaster
    80
    Some basic info here:
    http://www.ross-tech.com/vag-com/cars/audiB6.html
    Lots on this site if you do a search.
    Besides scanning for faults I have used mine for the following:
    Code instrument cluster following full DIS retrofit
    Code steering wheel/engine after Cruise control retrofit
    Adjust calculation of MPG
    Enable windows with remote
    Enable one-click all-doors unlock
    Enable beep on lock
    5aq1b likes this.
    May 2010
    Glasgow
    31
    thanks mate I'll have a look
    May 2010
    Glasgow
    31
    Quote Originally Posted by A4Ade View Post
    Ross-Tech: VAG-COM: Audi B6 VAG-COM Info
    Enable beep on lock
    Just noticed, someone has asked me if I'm able to code a new cluster for his VAG car but I didn't think I could do this as I'm sure the mileage on the cluster would also need amended? Or does the cluster read the mileage from elsewhere in the car?
    May 2012
    RETFORD, NOTTS
    1,753
    Milage can be changed with correct tools. I do this when i perform the actual cluster swap, I cant 'clock' cars for the hell of it :D
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    27,075
    It all comes down to what the car supports & the vcds module file details, best thing is to get the car & have a nosey round
    May 2010
    Glasgow
    31
    Quote Originally Posted by @udi A3 View Post
    ahhh ok. When you say tools - does that mean a different cable too? Pal of mine has a new cluster for his A4 B6 Chassis. Would be an interesting project.
  1. Logging turbo boost with VAG-COM
    By Ram in forum VCDS (formerly VAG-COM) forum
    Last Post: 26th January 2009, 22:23
  2. PDA version of VAG-Com....VAG-Check
    By Gambba in forum VCDS (formerly VAG-COM) forum
    Last Post: 14th January 2009, 09:09
  3. VAG COM purchase
    By DemianM in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th February 2008, 12:06
  4. obd vag com reset device
    By dann959 in forum A4/S4 forum(B5 Chassis)
    Last Post: 16th April 2004, 08:15
  5. Vag-Com Tunning for the Audi TDI
    By Pookie in forum Tuning
    Last Post: 29th July 2003, 21:13
