Chris NottEM Tuning
Like Tree1Likes
  • 1 Post By NHN
Thread: S4 Cab RNSE coding Issues
    Mar 2013
    Southampton
    128
    Wink S4 Cab RNSE coding Issues
    Hi,
    Having recently bought a cable from NHN, I have been trying to use it at every opportunity, so when I auto scanned my friends S4 B6 Cab, and found that it wasn't picking up the RNSE unit, I started googling possible issues, and the more I read articles on it the more it seemed that the RNSE was possibly retro fitted, especially as the car has impeccable history with all the handbooks etc. except one for the RNSE unit and there was a Audi Concert book in with the history. We had it confirmed by Audi, and this was the case.
    So I pulled the unit and had a look at the wiring, I found the wiring adapter plug B was not plugged in, and hanging free, in its place is an OEM Audi IPOD interface leading to an IPOD adapter in the glove box.
    Following the wiring adapter plug B back to the original Concert stereo plug there were two cables that were not connected any longer, though they were connected to the wiring adapter plug B, but as this was not being used they were not connected to the RNSE.
    Looking at the plug B that was in the unit from the IPOD Interface pins 3 and 5 were empty, and these happened to correspond to the same pins that the unconnected cables in the wiring adapter Plug B were connected too.
    Plug B pin 3 is V-Signal
    Plug B pin 5 is K-Line
    So I removed these two cables from the unused wiring adapter plug B and fitted them to the IPOD Interface Plug B, and result I got VCDS communication.
    So after Soft coding it with what I thought it should be I did another scan the unit had some fault codes logged, listed below,
    Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
    Part No SW: 8E0 035 192 C HW: 8E0 035 192 C
    Component: RNS-E HIGH EU H58 0650
    Revision: 11S Serial number: AUZBZ7F0431800
    Coding: 0413112
    Shop #: WSC 76091 146 85162
    VCID: 2441A3B9E40DA438643
    10 Faults Found:
    00446 - Function Limitation due to Under-Voltage
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 7
    Fault Frequency: 9
    Reset counter: 250
    Time Indication: 0
    Date: 2006.11.05
    Time: 19:11:10
    Freeze Frame:
    Voltage: 12.30 V
    Mileage: 655350 km
    Count: 65535
    Clock: 255:255
    00862 - Antenna for GPS Navigation (R50/R52)
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 249
    Time Indication: 0
    Date: 2013.06.14
    Time: 18:00:46
    Freeze Frame:
    Mileage: 655350 km
    Count: 1406
    Clock: 18:00
    00858 - Connection; Radio ZF Output to Antenna Amplifier
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 5
    Fault Frequency: 254
    Reset counter: 185
    Time Indication: 0
    Date: 2007.08.23
    Time: 12:04:20
    Freeze Frame:
    Mileage: 655350 km
    Count: 806
    Clock: 19:44
    00857 - CD Changer Unit (R41)
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 249
    Time Indication: 0
    Date: 2013.06.14
    Time: 17:30:52
    00466 - Control Module for Steering Column Electronics (J527)
    008 - Implausible Signal
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 194
    Time Indication: 0
    Date: 2007.08.21
    Time: 11:08:37
    01303 - Telephone Transceiver (R36)
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 194
    Time Indication: 0
    Date: 2007.08.21
    Time: 11:08:42
    00467 - TV Tuner (R78)
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 209
    Time Indication: 0
    Date: 2013.06.14
    Time: 17:50:28
    01044 - Control Module Incorrectly Coded
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 209
    Time Indication: 0
    Date: 2013.06.14
    Time: 18:05:44
    02446 - Disk Drive Mechanical Malfunction
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 229
    02005 - Coding Pin
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 249
    I then cleared all the above codes and soft coded the unit, but I then scanned for codes and it still kicked up the codes listed below,
    I then put the soft coding back as it was and it still produced the same codes as listed below,
    Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
    Control Module Part Number: 8E0 035 192 C HW: 8E0 035 192 C
    Component and/or Version: RNS-E HIGH EU H58 0650
    Software Coding: 0413112
    Work Shop Code: WSC 76091 146 85162
    10 Faults Found:
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 9
    Reset counter: 250
    Time Indication: 0
    Date: 2006.11.05
    Time: 19:11:10
    Freeze Frame:
    Voltage: 12.30 V
    Mileage: 655350 km
    Count: 65535
    Clock: 255:255
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 249
    Time Indication: 0
    Date: 2013.06.14
    Time: 18:00:46
    Freeze Frame:
    Mileage: 655350 km
    Count: 1406
    Clock: 18:00
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Reset counter: 185
    Time Indication: 0
    Date: 2007.08.23
    Time: 12:04:20
    Freeze Frame:
    Mileage: 655350 km
    Count: 806
    Clock: 19:44
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 249
    Time Indication: 0
    Date: 2013.06.14
    Time: 17:30:52
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 194
    Time Indication: 0
    Date: 2007.08.21
    Time: 11:08:37
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 194
    Time Indication: 0
    Date: 2007.08.21
    Time: 11:08:42
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 209
    Time Indication: 0
    Date: 2013.06.14
    Time: 17:50:28
    000 - -
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 209
    Time Indication: 0
    Date: 2013.06.14
    Time: 18:05:44
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 229
    02005 - Coding Pin
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 249
    Even with all these faults the unit still appears to work perfectly, it is running SW 650, and the only other thing I did was to code
    17 - Instruments so the Navigation directions would appear in DIS.
    Any one any ideas what are causing these issues any thoughts?
    Also what should the soft coding be in the RNSE in a A4 B6 S4 Cab, no MFSW, no telephone prep, no TV Tuner, it does have an Audi IPOD Interface unit (see above), the soft coding in the scans above were what I thought they should be.
    Any thoughts, help appreciated..
    27,099
    Try 0419113
    Mar 2013
    Southampton
    128
    Cheers NHN, what do you think regarding the fault codes its brought up? especially the control module for steering column electronics.
    27,099
    Just clear them a few times, they usually go away on cars they've come up on I've worked on & I'm anal so I check about 10 times to be sure lol.
    Andy27168 likes this.
    Mar 2013
    Southampton
    128
    Cheers, will code it up again tomorrow with the code you have suggested.
    Will update the post on any change.
  1. 2002 audi cab fault codes help
    By bowmeat in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th June 2014, 18:57
  2. RNSE Coding - Help Please
    By geraint.davies in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th March 2010, 07:44
  3. RNSE Ipod Issues
    By Boydie in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th January 2010, 08:13
  4. EVAP Code Issues
    By hoppy760 in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th December 2009, 21:47
  5. RNSE - Bose issues
    By crypric23 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st November 2009, 14:45
