Badger5JMB Retrofits
Results 1 to 26 of 26
Like Tree1Likes
  • 1 Post By bearthebruce
Thread: Fault codes
    Jun 2013
    13
    Fault codes
    Hi guys after some help had to call the rac out as my a3 1.8t wouldn't start been temperamental last few weeks cutting out crap idle revs,
    rac put there computer on and up popped 14 fault codes the guy was baffled along with the audi technician he also rung who suggested down the phone to set fire to it!
    The codes I have as follows
    18010 battery voltage to ECM to low
    575 camshaft position sensor
    16500 coolant temp sensor
    532 supply voltage b+
    16885 vehicle speed signal implausible signal
    1165 throttle body control module
    17967 idle switch on buse setting
    1249 1250 1251 1252 there cylinders 1 to 4
    1247 no info as rac man ran out of room
    1262 same as above
    2224 same as above
    Any help would be greatly appreciated
    codes were reset and came back when engine was cranked over
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,487
    ​Where are you located? What year is the car?
    Jun 2013
    13
    Sorry my car is w reg and I am located in cornwall
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,487
    Quote Originally Posted by Stretchykid View Post
    The
    https://maps.google.co.uk/maps/ms?ms...5&source=embed
    the link above is for the map, just click it and it will take you straight to it, click the blue balloons in your area, a name pops up and just send the user a pm asking them to scan your car for faults/resetting etc. x
    27,121
    That's allot of errors which leads me to believe its a power feed issue, battery or alternator maybe?
    Jun 2013
    13
    Battery still cranks over and the lights are all ok it was suggested I put it on a diagnostics machine
    27,121
    Yes that would be a good start.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,019
    Where in cornwall?
    I'm in plymouth and have VCDS lite if its of any help to you.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    Jun 2013
    13
    I live in bodmin this may sound stupid but what will thevcd thing do that rac computer didn't I'm not car knowledgable like that
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,019
    Not a lot really.
    VCDS might give you a better explanation of the error codes over the RAC unit.
    Jun 2013
    13
    Thanks very much for the offer have got a guy coming Monday with a machine if u was any closer I'd of taken up your offer, I am not to confident after tha rac man saying its like looking for a needle in haystack! I have read in quite a few places it may just be the crankshaft sensor I dunno I'm no mechanic at times like this I wish I was though
    May 2012
    RETFORD, NOTTS
    1,753
    VCDS will tell you MUCH more than most generic machines.
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    Jun 2013
    13
    Had the car looked at today with a vcds and the guy reckons maybe the ecu so I am needing to get the ecu tested any suggestions on best place to send it also would I be able to put a different ecu in?
    May 2012
    RETFORD, NOTTS
    1,753
    You can fit another ecu yes, but you need to either buy one with an immobiliser delete, or have somebody read your security codes and adapt the new ecu with VCDS to your car. Very straightforward job, I did one on a mk4 golf a week ago when he fitted a new turbo conversion to a non turbo!
    Do you have the log from VCDS, im sure others on here will be able to advise you better before removing the ecu.
    bearthebruce's Avatar
    Ross-Tech, LLC
    Jul 2006
    Ambler, PA
    331
    Quote Originally Posted by @udi A3 View Post
    I second this notion... The ECU is expensive. Most often there are other problems that may be at the root of your problems and fitting a new ECU may not be the solution. It is probably the most expensive solution! Post the autoscan and get opinions from others before spending on a new ECU.
    For example, the low voltage faults - did you have a low battery? replaced or re-charged it recently? Those faults can be ignored if that is the case.
    The sensor faults however could be an ECU or it could be wiring. Many of the sensors share a common signal from the ECU that is a reference to the sensors. Could that signal from the ECU have failed? Is it wiring? is one of the sensor shorted and pulling that signal to ground? If a short exists, would it damage a new ECU?
    Don't shot gun this repair. Do your homework. Go to erWin and get the wiring diagrams and get your meter out. Spend the time to make sure you know what the failure was and fix it right.
    NHN likes this.
    -Bruce-
    Ross-Tech, LLC
    Bruce@Ross-Tech.com
    Jun 2013
    13
    Hi guys I have purchased a crank sensor and am going to try that any ideas on where it is located? I am waiting for the guy who read the code to tx me the numbers
    Ross-Tech, LLC
    Jul 2006
    Ambler, PA
    331
    Good luck!
    -Bruce-
    Ross-Tech, LLC
    Bruce@Ross-Tech.com
    Jun 2013
    13
    Thankyou I think I have found the problem the round thing below the battery there is a sensor and I think it was already knackered been bodged once before has broken both wires I have now got the task of changing it
    Apr 2013
    Aberdeenshire
    595
    Do you have a photo of it ?
    Jun 2013
    13
    Jun 2013
    13
    This is behind the starter motor on the gearbox and its broke an I clutching at straws thinking this could be my problem
    Apr 2013
    Aberdeenshire
    595
    Not sure what is but it could be a road speed sensor or reverse light switch both guesses though.
    Jun 2013
    13
    I was thinking the same, I can't see that stopping the car running though can you?
    Apr 2013
    Aberdeenshire
    595
    looked back at your faults and road speed sensor is listed so I think that's it however I would suspect a non start could be due to your camshaft sensor or could it be your timing that's out ? Hard to say could even be a bad battery I think a good vcds session would help though
    Jun 2013
    13
    Well I am picking up the part shortly so fingers crossed, I have a new crank sensor also which I am going to try as well
    Apr 2013
    Aberdeenshire
    595
    Do you have corrodes earths as that could give loads of issues if they are bad
  1. S6 Fault codes
    By bigmoose in forum General Technical / How To
    Last Post: 16th June 2005, 16:16
  2. Help: Fault code 16795
    By imported_rustys3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd June 2005, 17:17
  3. information on fault codes
    By vwjin in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th October 2004, 00:45
  4. Fault Code
    By gman in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th July 2004, 16:44
  5. fault code
    By tp7n in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th December 2003, 14:05
