Sky InsuranceJMB Retrofits
Results 1 to 11 of 11
    Aug 2012
    Question A4 B8 2.0 TDi: DPF = Differential Pressure Sensor Faultly
    Hi,
    Stangely, just after getting all my light to LEDs, I get the motor lght lighting.
    I plug my VAG cable, get an autoscann and I get this error:
    Address 01: Engine (J623-CAGA) Labels: 03L-906-022-CAG.clb
    Part No SW: 03L 906 022 NN HW: 03L 906 019 AL
    Component: R4 2,0L EDC H21 5483
    Revision: 25H21---
    Coding: 0A194012232403080000
    Shop #: WSC 06325 000 00000
    ASAM Dataset: EV_ECM20TDI03L906022NN A02006
    ROD: EV_ECM20TDI03L906022NN_AU48.rod
    1 Fault Found:
    5262 - Diesel Particle Filter; Differential Pressure Sensor: Short to GND
    P2454 00 [039] - Defective
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 52514 km
    Date: 2013.05.22
    Time: 17:47:31
    Readiness: 0 0 0 0 1
    I go thru ETKA and find where is located this sensor, I take a picture to get the right reference...it's seems quite simple to replace.
    So seems that my Differential Pressure Sensor has to be replaced? (Only after 52000Km!!)
    What do you think?!
    May 2013
    60
    Replace the sensor with a new one, prone to failures.
    When you remove the rubber pipe from the sensor, blow into them with compressed air.
    Aug 2012
    OK, thanks for advise
    I order the sensor yesterday....
    Jan 2011
    northants
    165
    you may need a software update on the new pressure sensor!
    the last 2 that i have fitted worked perfect but the light will still come on until i had a software update done
    Aug 2012
    software update?
    you mean firmware?? strange
    May 2013
    60
    Do not touch software.. Change the first sensor ,Replace the sensor with a new one, prone to failures.When you remove the rubber pipe from the sensor, blow into them with compressed air.
    KalEl's Avatar
    Mar 2013
    Moray, Scotland
    14
    They came out with a new sensor, I had a faulty differential sensor which resulted in me replacing dpf, diff sensor, vacumm & software update. Wasn't cheap the part should comes with a 2 year warranty
    Jan 2011
    northants
    165
    its a software update !!
    the ecu is updated to alter the parameters for the pressure sensor you sometimes get a little instruction note in the parts box telling you this!
    Aug 2012
    Hi guys,
    So, I finally buy new sensor, I've just replaced it, clear the faults, stop and start the engine several times...and seems that the error disappear!
    I will see if it's appear after a short drive next week
    Only on thing, I find this procedure to make the adaptation of the new sensor:
    After fitting the g450 sensor adaption is simply as follows:
    Select engine (01)
    Login or coding 11
    Type 30605 in the box and login.
    Close controller,exit vcds. Switch ignition off ( i jumped out and locked the car for 30 seconds to be sure to send everything to sleep.
    I have tried to realize this once my sensor get replaced BUT I can't access the "Login or Coding 11", It' grayed :s
    Should I really to this adaptation?
    If yes, how can I access this "Login or Coding 11" section??
    Thanks for support
    BR
    May 2013
    60
    Carry out test drive .If everything is ok, do not do anything else.
    You can optionally check these values:
    104 Particulate filter
    Only on vehicles with particulate filter
    Oil ash
    [Ltr]
    Soot mass calculated
    [g]
    Soot mass measured
    [g]
    Distance since last regeneration
    [km]
    Audi Portal: ECU Diagnostic . Audi A4 8K (2008-) . Engine Control Unit J623
    Heisenberg's Avatar
    Jun 2011
    Manchester
    65
    Sorry for the thread revival but does anyone know why the box is greyed out for coding ii 11?? Entered in the security code but still nothing.
    Genuine Full VCDS - PM for details (Manchester)
  1. Error 001137 Exhaust Pressure sensor Fault. Advice
    By a3mad in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th May 2013, 12:33
  2. ABS and ESP lights - Brake pressure sensor fault - Help!
    By wilkoa6 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 25th March 2010, 15:45
  3. A3 TDi DPF / ESP Error Non Starter??? HELP
    By Indie_DSG in forum Diesel forum
    Last Post: 18th June 2009, 11:34
  4. A3 Sportback 2L TDI DPF option code?
    By Geraldy212 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th August 2008, 00:14
  5. Audi A3/Sportback 2.0 TDi (DPF)
    By dorgan in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th June 2005, 22:01
