EM TuningMonster Motorsport
    Jan 2011
    683
    A4 Cab b6 alarm horn short to ground.
    Hi,
    had the dreaded alarm siren failure by corroded batteries etc. Fitted a new second hand unit today and still hazards flash but no sound. Scanned with vcds lite and get...
    01134 alarm horn h12 29.00 short to ground.
    soon as I clear it then it returns.
    Im not actually sure it's a fault of if the rechargeable cells inside have to charge up first before I will hear any sound. Does anyone know ?
    Many thanks.
    2003 A4 Cab 2.4 V6 Manual / 43k miles genuine woohoo (on a 10 year old car lol) / Ebony Black Metallic / Full Grey Leather / Fully Electric Seats / Heated Seats / Interior Light Pack / Cruise / Wood / Bose Symphony II / Black roof
    27,079
    Mine worked straight of the bat, so you sure its not a faulty unit again, definitely new unit as second hand & new in same sentence seems contradictive :P
    Jan 2011
    683
    Thanks for the quick reply. It was an ebay job, stated as tested and working but hard to tell. It was listed as for a TT but pared code is identical to the one I removed. I'm wondering if it does need charging up from the car first though.
    27,079
    Well take it for a little run, that will give it a charge, check your coding is correct aswell for horn warnings, then test.
    Jan 2011
    683
    Roger that. Cheers. Will update later.
    Jan 2011
    683
    Well it's been on a 40 mile drive, still no sound only flashing lights. When I scan with vcds lite I get the h22 short to ground, if I unplug the siren I get the no communication error as you would expect. I'm wondering if my ebay purchase is a duffer.
  1. Alarm horn activation
    By mattandrew in forum VCDS (formerly VAG-COM) forum
    Last Post: 3rd November 2007, 23:04
  2. Alarm horn location...?
    By S3 YEA in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th November 2006, 19:21
  3. 01134 - Alarm Horn - No communications
    By Stringster in forum VCDS (formerly VAG-COM) forum
    Last Post: 11th November 2006, 14:49
  4. Alarm horn location?
    By VAGMAN1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th June 2005, 16:44
