Chris NottAH Fabrications
    jonnycraig's Avatar
    Jun 2009
    Port Talbot
    158
    '96 B5 Codes (1.9TDI 1Z) Scan results (Lack of power)
    Hi, heres what VAGCOM brought up.
    Car seems turboless at the minute, still gets up to motorway speeds but takes a while!
    IMHO the Catalytic convertor is knackered as blocking the exhause pipe.
    5 Faults Found:
    00575 - Intake Manifold Pressure - If the Cat was broken up would this do it? (Can I deCat it and still pass MOT?)
    17-10 - Control Difference - Intermittent
    00741 - Brake Pedal Monitoring -This one was existing from the last time I scanned, need to replace brake switch
    27-10 - Implausible Signal - Intermittent
    65535 - Internal Control Module Memory Error - ????
    00-00 - -
    17978 - Engine Start Blocked by Immobilizer -Immob light was flashing during tests, key out and in sorts this most times.
    P1570 - 35-00 - -
    00553 - Mass Air Flow Sensor (G70) - I did this, unplugging / reseating the MAF
    31-10 - Open or Short to Ground - Intermittent
    Im afraid to clear the codes and see what ones stay behind as was told that cause the car is in limp mode now it may not start after clearing as it presumes its in the garage lol?
    Jonny
    1996 A4 B5
    1.9TDI SE
    Gone but not forgotten
    Audi A4 2.5TDI Quattro
    Skoda Octavia 1.9SDI (Wont be missed lol)
    26,762
    If you search the net with those codes you'll find some answers, ideally you should clear them & then drive & rescan.
    May 2013
    60
    • The measured values must be printed out or read (2nd person required) when the revolutions reach 3,000 rpm.
    → Indicated on display:
    Read measured value block 11 "
    3340 rpm 1830 mbar 1850 mbar 68 %
    Display zone Display on V.A.G 1551/1552 Possible cause(s) of fault Fault remedy
    1 =
    Engine speed
    2850...3150 rpm OK ---
    2 =
    Charge pressure (specified)
    1900...2000 mbar OK ---
    3 =
    Charge pressure (actual)
    1700...2500 mbar OK ---
    Below 1700 mbar Charge pressure control defective - Check charge pressure control
    => Page 23-67
    Turbocharger defective
    Charge pressure hose not connected to control unit - Connect charge pressure hose
    Above 2500 mbar Turbocharger defective - Check charge pressure control
    => Page 23-67
    4 =
    Duty cycle from charge pressure control valve
    do a test drive with the driver, you read a real values in the channel 11, 10 and save the logs and attach
    before the test drive, delete all memory errors
    45...94 % OK ---
    jonnycraig's Avatar
    Jun 2009
    Port Talbot
    158
    Dunno if this helps anyone understand whats happening, lack of funds are stopping me taking it to a garage so need to find out as much as possible so I can just tell them whats wrong rather than waste money and time getting them to diagnose it as well. I was told that the yellow line should follow the green closely as for what it means .. no idea lol!
    Jonny
    Measuring block 11 - VagScope
    1996 A4 B5
    1.9TDI SE
  1. my scan results hmmmm
    By dplovin in forum VCDS (formerly VAG-COM) forum
    Last Post: 4th November 2012, 08:30
  2. New Scan Results ?
    By A3 T in forum VCDS (formerly VAG-COM) forum
    Last Post: 17th May 2011, 18:58
  3. My scan results S3 8L
    By rhubarb4 in forum VCDS (formerly VAG-COM) forum
    Last Post: 28th April 2011, 13:07
  4. Haglos' VAG-COM Scan Results
    By Caesium in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd February 2009, 00:01
  5. vag-com abs scan results, couple of questions.....
    By darby7 in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th July 2005, 11:47
